![]() Join Date: May 2009
Ball joint ID help
I am going to put drop spindles on my 67 which the PO has already coverted to front disc. Is there any way to look at the ball joints or measure them to know if they are the 67 style or the newer style with out taking the spindle off. Any and all info will help. thanks
Suburban Hick
![]() Join Date: Aug 2008
Re: Ball joint ID help
I would say that if its an original gm disc setup like off a 71 or 72 than its definitely been converted. If by looking at it the upper looks fairly small than its probably been converted as well. If i was close to my truck i would give you some measurements. I've been through all this hassle. It may not be a bad idea just to replace the ball joints while you are in there as well and then you can put whichever style you want in.
Mathew 1947 Chevy 3600 1951 GMC 100 1969 Chevy C-10 396/500hp TH400 lowered 4" 1968 Imapla Custom 396/325hp TH400 "Grandmas Car" 1976 Crew Cab 4x4 diesel http://67-72chevytrucks.com/vboard/s...d.php?t=488505 1978 Chevy K-10 454 1983 S10 4x4 "Bumblb" (Grandpa's truck) 1993 Chevy S10 V8 conversion 1990 Ford Probe Gt 1992 Dodge W-150 "Old Man's Truck" 1992 Pontiac Grand Prix SE 1992 Mercury Grand Marquis-Mercruiser 2000 Ford F150 (Currently my mother drives this) 1946 Farmall H with Stan Hoist loader 1965 John Deere 110 1961 Wheel Horse " Rat Tractor" |
