Old 01-15-2010, 12:13 AM   #1
198plus
198plus's Avatar
12 Bolt Carrier ID
Just trying to ID this carrier
198plus is offline   Reply With Quote
Old 01-15-2010, 01:41 AM   #2
Captainfab
60-66 Nut
Re: 12 Bolt Carrier ID
Well for starters, what are the numbers on the ring gear? There should be a part number, a date, and the tooth count of the ring and pinion. This will be a start in figuring out just what it is.
Old 01-15-2010, 03:55 PM   #3
62gmc910
62gmc910's Avatar
the differential is a eaton positive locking manufactured for general motors for the truck 12 bolt
unless the gears are changed they were 3.73 41 -11
or its a miss marked dana posi trac but I think its an eaton
62 GMC 910 short fleetside 454 super t10 14 bolt
w/gov lock 70s c20 front discs (built in the 80s)
65 GMC 930 dualwheel 292 4spd all origonal 39k mi(my sons truck)
63 GMC 950 camperized school bus, (Gus the bus)
350 4speed 2 speed rear
64 GMC 950 "spare" bus 283? 4speed detroit locker
53 GMC 1ton dual wheel bus
78 GMC c25 short course off road race truck(son's truck)
355 th400 14 bolt (www.wheel2wheel.ca)
88 Peterbilt 379 longhood (hauls race truck)
62gmc910 is offline   Reply With Quote
Old 01-15-2010, 04:01 PM   #4
70 Suburban
Rods
If you dont want it...send it to me
Just keepin it simple.
1965 C-10 Ext cab build. 350??(Does it count at 2 truck if I had to cut one up?)
1966 C-10 lwb 283 auto
1970 Suburban in pieces
1971 Blazer 4wd....restore someday. all factory CST
1972 Blazer 4wd parts truck still a roller
1972 GMC Sierra Grandee
1998 Chevy ext driver.
2005 F**D the wife drive...(cant fix women)
70 Suburban is offline   Reply With Quote
Old 01-15-2010, 07:38 PM   #5
198plus
198plus's Avatar
I figured it was a four series carrier, wasn't sure if it was an Eaton.
