Old 01-15-2010, 01:43 AM   #1
jmedero
jmedero's Avatar
+18 offset wheels. Will they fit?
Well I have the chance of getting a NIB set of wheels that have a +18mm offset. 20x9 and 22 in rear. Anyone have an idea if this will work and sit tucked in? Truck is in the process of being bagged. Thanks. And if any pics out there post them. Thanks.
68 BB burb build thread Scott's super slam front/rear
http://67-72chevytrucks.com/vboard/s...d.php?t=378084
jmedero is offline   Reply With Quote
Old 01-15-2010, 08:57 PM   #2
jmedero
jmedero's Avatar
Re: +18 offset wheels. Will they fit?
ttt
Old 01-15-2010, 09:22 PM   #3
lolife99
67-72 parts collector,…
lolife99's Avatar
That's about 5.75" bs.
(same as an 8" rim with 4.75" backspace)
6" BS on a 9" rim would be better in my opinion.
It will be close.
Old 01-15-2010, 09:24 PM   #4
lolife99
lolife99's Avatar
Which rearend do you have?
Old 01-15-2010, 09:41 PM   #5
Hart_Rod
Hart_Rod's Avatar
The narrow one (68 GMC).
Hart_Rod is offline   Reply With Quote
Old 01-15-2010, 10:03 PM   #6
lolife99
lolife99's Avatar
Might need spacers on the rear.
Old 01-15-2010, 10:39 PM   #7
jmedero
jmedero's Avatar
Cool guys thanks. Just trying to see if they are worth it. I can get the set for $500.
Old 01-15-2010, 10:46 PM   #8
Hart_Rod
Hart_Rod's Avatar
Wheel spacers are pretty cheap.......
Old 01-16-2010, 12:22 AM   #9
jmedero
jmedero's Avatar
here are the wheels. What do you guys think? Chrome ones are 20x9's and painted are 22x9.5
Old 01-16-2010, 01:00 AM   #10
Strut
Strut's Avatar
It will be close.
Can you give a brief description on how to read the chart, thanks.....
1972 Chevy C10 SWB
1999 GMC Sonoma Mini
2008 Yamaha R1
2007 Harley Nightster
Strut is offline   Reply With Quote
Old 01-16-2010, 06:24 AM   #11
lolife99
lolife99's Avatar
1) pick your "wheel width" on the left hand column.
(It doesn't matter what diameter)
2) scroll across that line and find your (-) offset or (+) offset.
3) look directly above that at the top for "back spacing" in inches.
Something like a +18 will fall between +12 and + 19 on that chart.
Closer to +19.
(which is 5.75" backspace on a 9" wide rim)
Just remember,... a different width wheel and you offset number will mean different backspace.
