01-15-2010, 01:07 PM | #1 |
1965 Chevy C10, 2005 4.8L/4l60
63-66 with LS engines- emergency brake ?
What are you all doing with your emergency brake mount/assembly? I need help or ideas please
Clyde65 Rebuild of Clyde http://67-72chevytrucks.com/vboard/s...84#post8338184 69 Aristocrat Lo Liner build http://67-72chevytrucks.com/vboard/s...84#post7561684 support our troops! |
01-15-2010, 06:43 PM | #2 |
Re: 63-66 with LS engines- emergency brake ?
I decided not use an ebrake with my 6.0/4l80e swap, so I removed both crossmembers and all the e-brake cables, etc. I am going to use a early 80's chevy 4X4 crossmember for my 4L80e.....Used an air hammer/chisel to pop the rivets out on the cross members. I had accidently bent up my ebrake xmember with a floor jack.
01-15-2010, 11:50 PM | #3 |
Clyde,
I am swapping a 6.0L with T56. I removed the E-brake cross member and fabricated a new crossmember for the T56. I then fabbed up a new E-brake assembly and welded it to the new cross member. I had to shorten the E-brake cables a little but otherwise it works like the original. I'll try to post some pictures tomorrow. TR
1965 C10 SWB Fleet Two owner LS2 Swap Thread http://67-72chevytrucks.com/vboard/s...d.php?t=413880 |
01-16-2010, 01:50 AM | #4 |
I have always thought about maybe trying lakewood's universal e-brake kit since I am missing several parts to make my e-brake work. I think that one of these kits may even work with the factory brake lever if a person is creative enough. The price may be the only thing keeping me from giving it a whirl. Just my $.02.
01-16-2010, 01:52 AM | #5 |
Rods
im goin to use the foot e brake from a 85 chevy
Just keepin it simple. 1965 C-10 Ext cab build. 350??(Does it count at 2 truck if I had to cut one up?) 1966 C-10 lwb 283 auto 1970 Suburban in pieces 1971 Blazer 4wd....restore someday. all factory CST 1972 Blazer 4wd parts truck still a roller 1972 GMC Sierra Grandee 1998 Chevy ext driver. 2005 F**D the wife drive...(cant fix women) |
01-16-2010, 02:32 AM | #6 |
60-66 Nut
The '66-'72's did away with the crossmember and linkage and replaced it with another cable and a couple of hooks to the frame. One of these setups may be easier to make work in your application.
01-16-2010, 10:44 AM | #7 |
Here is the PDF from LMC that shows the cable and hooks that Captainfab mentioned.
01-16-2010, 10:26 PM | #8 |
Clyde,
Here are some pictures of what I did for the e-brake. The assembly is out of the truck for painting but I fully tested it. I wanted to keep it as close to stock as possible. TR
01-28-2010, 03:49 PM | #9 |
ooooo, cool! Can you make me one? JK, I have absolutely no talent for welding and such. I think I may just do the 66-7? option, although I hate to sink more $ into this process, wish I would have known then, I would have done it before the 5.3/4l60e went in.
