Old 01-15-2010, 06:38 PM   #1
BigBlock67
Rusty metal and welding?
I've been cutting out several rusted areas and I am getting ready to weld in some patches. Some places are solid but a little pitted. Is there something I should spray on these areas to kill the rust and prepare it better to weld? Thanks for any help or ideas.
BigBlock67 is offline   Reply With Quote
Old 01-15-2010, 06:40 PM   #2
420am
420am's Avatar
Re: Rusty metal and welding?
I don't know.. just DO NOT use Brake Cleaner.
http://www.brewracingframes.com/id75.htm
1972 Long Bed Cheyenne
Build Thread: http://67-72chevytrucks.com/vboard/s...d.php?t=285282
Waste my bandwidth and listen to some great tunes >> http://www.radioxenu.com (Live Shows with yours truly every Friday)
420am is offline   Reply With Quote
Old 01-15-2010, 07:23 PM   #3
mbgmike
Not really. Rusted pits do not like to be welded. If its tiny you can. But in general you will just burn a hole thru them. You really need clean metal. Their was a company that was making spray migs that blew hot metal over pin holes but I think they went out of business.
mbgmike is offline   Reply With Quote
Old 01-15-2010, 08:30 PM   #4
cdowns
cdowns's Avatar
i'd either sandblast the edges or go over them real well with a coarse wire wheel to clean for a good weld
Old 01-15-2010, 08:36 PM   #5
tim21391
tim21391's Avatar
id say the sandblast thing works.. they have a handheld gun at a hardware place for like 20 bucks i think i used it before and its alright.. on my truck when i skinned the doors today i had rusty metal and the 110 welder i used was just fine.. i grinded it down a bit and then turned the heat down and it welded alright if u blow a hole threw it just do small tacks let it cool then do it again.. good thing for metal is u can weld and grind so its hard to screw it up
1972 C-10...402/400..flowmaster 40 series
1967 Mustang 347 stroker/C-4
1966 Mustang 289/3-speed
2013 Mustang V6/6speed w/300 ponies
I may be 23, but i sure do knows 67-72s are sexy!
Its not MPG its smiles per gallon!
build started 11/25/08
build thread: http://67-72chevytrucks.com/vboard/s....php?p=2993796
tim21391 is offline   Reply With Quote
Old 01-15-2010, 11:19 PM   #6
Mxracer202
Mxracer202's Avatar
Exactly. when I was going to weld up a bunch of cracks in he bottom of my door it was all VERY rusted. so i just took a wire wheel grinded all the rust off and tried to patch it the best I could but kept burning through the metal, so i just laid a few tacks and let it cool and just repeated. worked fine
58 Jeep willys pickup
67 K10 4x4- soon to be trail truck
TROUBLE MAKER RACING
"If you can't stand BEHIND our troops, please stand in FRONT of them."
Mxracer202 is offline   Reply With Quote
Old 01-16-2010, 02:25 AM   #7
tim21391
tim21391's Avatar
ya patience is the key to success
Old 01-16-2010, 07:38 AM   #8
Why pee into the wind?Cut until you get good metal.I hate when rust comes back through all my hard work.I know a guy that had his Blazer all restored.He said it had new sides put on.I believe they were either patched or modified truck bedsides.It was a nice Blazer,except it was bubbling at the edges of all the welding.He was so bummer he sold it after all he put into it...for $1,300 with wheels & tires he paid $1,000 with barely any wear.I didn`t even want it.I`d rather deal with original rust than pieced together rust.
Old 01-16-2010, 12:58 PM   #9
deek114
deek114's Avatar
I am a welder. At work I would send it out to be sand blasted, but since this is coming out of your pocket...... wire wheels are your friend. Clean all of the pits out with a wire wheel and a die grinder. If you don't you will get porosity. If that happens in that thin of metal you will be doing some cutting.
Friends don't let friends drive fords.
deek114 is offline   Reply With Quote
Old 01-17-2010, 01:33 AM   #10
dlillis
I agree with special-K 100%
Hugger Orange/White '70 CST/10 327/TH350
dlillis is offline   Reply With Quote
Old 01-17-2010, 02:29 AM   #11
GMC tom
I would say grind it down to the metal.I know you might have sections that need to be welded i would make sure what you welding too is good metal.also what are you going to do for that same area to stop anymore rust/corrosion..we used a rust converter por 15 or something just go to any autobody shop/automotive paint store. on the inside of that panel...nothing sucks worse is too have you vehicle right and to have rust bubbles come through you paint a short while later.I do alittle paint and body thats what i graduated from school from and finsihed the welding course too. I justn thinkm people forget what causing the rust sometimes..sorry if i went off course from the original thread top pick.
GMC tom is offline   Reply With Quote
Old 01-17-2010, 10:04 AM   #12
When you weld your patch that old rust will come back with a vengence,trust me.Even weld-through primer burns some.
