01-15-2010, 06:47 PM | #1 |
Between Trucks...
Door Problems
Driver's side door is driving me nuts. Have to slam it 4 or 5 times before the latch catches and the door stays closed. Sometimes after slamming it shut I can't get the door to open. Is this a door latch problem or a door adjustment problem?
Beat it to fit, Paint it to match... |
01-15-2010, 07:03 PM | #2 |
Re: Door Problems
Couple of questions:
Did you install new door weatherstrips? Have you check the pins on the door hinges for wear?
Get your facts first, and then you can distort them as much as you please!!!!!. Sylvester's build thread >>>http://67-72chevytrucks.com/vboard/s...ht=big+rebuild |
01-15-2010, 07:19 PM | #3 |
Between Trucks...
Re: Door Problems
Door weather strips have been in for quite a while. Haven't checked the pins on the hinges, but they seem tight.
01-15-2010, 11:33 PM | #4 |
The Older Generation
Re: Door Problems
Try lifting up on the door when you open and close it... Does that make a difference? LockDoc
01-16-2010, 11:50 AM | #5 |
Between Trucks...
Re: Door Problems
Haven't tried lifting the door while closing it, because I'm in the cab.When I'm outside the cab it closes alright. Lifting the door while trying to open it when it's stuck doesn't seem to help.
Beat it to fit, Paint it to match... Last edited by Sinister; 01-16-2010 at 11:51 AM. |
01-16-2010, 12:23 PM | #6 |
Re: Door Problems
have you greased the pin and latch assy?
01-16-2010, 12:28 PM | #7 |
Between Trucks...
Re: Door Problems
Haven't greased it, will do. What is the pin?
01-16-2010, 01:21 PM | #8 |
Re: Door Problems
pin i mean is what the latch from the door hooks onto
i'd spray the latch real good with WD40 to clean then a bit of white grease on the parts// if you dont have white regular wheel bearing grease will do
01-16-2010, 01:39 PM | #9 |
Between Trucks...
Re: Door Problems
I'll grease it up and see how it goes.
Beat it to fit, Paint it to match... Last edited by Sinister; 01-16-2010 at 01:39 PM. |
01-16-2010, 02:17 PM | #10 |
Grand PooBaa Member
Re: Door Problems
Hey Sin, I would clean and scotch brite every part of the door latches that have to do with opening and closing the door. From the cab parts to the door parts. Then use the grease.
01-16-2010, 04:41 PM | #11 |
Between Trucks...
Re: Door Problems
Alright Vince, will give that a shot.
01-16-2010, 07:43 PM | #12 |
Grand PooBaa Member
Re: Door Problems
Did it work?
01-16-2010, 07:53 PM | #13 |
Between Trucks...
Re: Door Problems
Had to do some honey-do's today. Gonna mess with it tomorrow.
01-16-2010, 08:32 PM | #14 |
Between Trucks...
Re: Door Problems
Lubed it up. Seems to be working O.K. for now. Thanks everyone.
01-17-2010, 02:46 PM | #15 |
Between Trucks...
Re: Door Problems
I spoke too soon. Door seems to close alright, but sometimes it's sticking shut. Hmmmm, I'm perplexed.
01-17-2010, 04:48 PM | #16 |
Grand PooBaa Member
Re: Door Problems
Check for loose brackets, bolts, hinges. Might need a wrecking yard run to change your door hinges on the door and cab.
01-17-2010, 04:53 PM | #17 |
Between Trucks...
Re: Door Problems
Hinges seem tight and solid, so I'm still perplexed. I'm thinking the latch in the door might be bad.
