01-15-2010, 08:19 PM | #1 |
Registered Chevy Owner
Six lug rear disk brake conversion ??
I spent a while going through all the threads I could find about disk brake conversion and I really couldn't find what I was looking for.
I'm going to the pull a part on Sunday and I'm wanting to know what parts I need to look at getting for the conversion. Is there a late model truck or something that already has disk brakes that I could just take everything off of? Thanks Nick + Forgot to say. I have a '71 4x4 1/2 ton
Love is fleeting, but Chevy trucks are forever!!!! 1970 Chevy CST C10 long box 350/400 2008 Chevy Silverado short box 4x4 Had; 1951 Chevy short box 307/T5 1988 Chevy shot box 4x4 350/350 1971 Chevy C10 long box 4x4 350/350 1971 Chevy C20 long box 350/350 1971 Chevy C10 long box 350/350 Last edited by nickp51chevy; 01-15-2010 at 08:20 PM. Reason: + |
01-15-2010, 08:21 PM | #2 |
Re: Six lug rear disk brake conversion ??
rear end from a newer truck or tahoe but I think you need 16" or larger rims... or a CPP set would work.
depends on if you need an Ebrake or not.
The Garage: 1968 K-10 SWB - "Project Money Pit" 1996 Z-71 - "huntin rig" 1969 C-10 LWB (SOLD) "Project flip that truck or else" 1993 Passport, F@rd 1-ton (SOLD)"Project Cousin Eddie" My Garage Build "The 1,000 footer" |
01-15-2010, 08:41 PM | #3 |
I'd like an e-brake but don't need one. I'm going to put the stock wheels back on when I get them refinished.
Love is fleeting, but Chevy trucks are forever!!!! 1970 Chevy CST C10 long box 350/400 2008 Chevy Silverado short box 4x4 Had; 1951 Chevy short box 307/T5 1988 Chevy shot box 4x4 350/350 1971 Chevy C10 long box 4x4 350/350 1971 Chevy C20 long box 350/350 1971 Chevy C10 long box 350/350 |
01-15-2010, 09:06 PM | #4 |
I just searched CPP, and I'm wanting to keep the cost on the down low; or low down.
01-15-2010, 10:54 PM | #5 |
low cost and rear disks aren't easy...
01-15-2010, 10:58 PM | #6 |
67-72 parts collector,…
01-16-2010, 12:17 AM | #7 |
I know its not going to be easy, but I still want to try.
I already have. They want $400-$550 for a set up.
01-16-2010, 10:12 AM | #8 |
check out my build thread, i used 91 chevy front rotors, had brackets cad'd up and some caddy calipers
James 1968 GMC "HAVOC" 1986 GMC "Frank" J.J.R.H. Design & Consulting My 68`Rebuild "HAVOC": http://67-72chevytrucks.com/vboard/s...d.php?t=316300 A 58' chev build thread: http://www.67-72chevytrucks.com/vboa...d.php?t=311238 1969 Camaro Pro Touring http://67-72chevytrucks.com/vboard/s...61#post3513361 Swiss Cheese: http://67-72chevytrucks.com/vboard/s...d.php?t=384390 Adjustable Trailing Arm How-To: http://67-72chevytrucks.com/vboard/s...d.php?t=321100 1968 Ford Farm Truck: http://67-72chevytrucks.com/vboard/s...=1#post6555587 |
01-16-2010, 02:57 PM | #9 |
I was thinking about getting the front rotors of that body style truck. Then I was gonna go and start taking off calipers from other cars to see what would fit. What year of Caddi should I be looking at?
01-16-2010, 03:02 PM | #10 |
some use caprice or camaro calipers as well as the caddy... not sure which one's have the E-brake
01-16-2010, 03:41 PM | #11 |
should I get the prop valve from what ever vehicle I get the calipers from, if they are disk/disk?
01-16-2010, 10:12 PM | #12 |
ttt
01-24-2010, 02:00 AM | #13 |
i used a wilwood prop valve and the rear discs from a 79 caddy deville, or seville.
01-24-2010, 02:22 AM | #14 |
I will look into that. I found out from a local guy that works at the Napa that I go to that the front rotors and calipers from a square body will work, and he has a set of braskets that he'll let me trace so I can make a set. I'll let you guys know when I get them.
