Old 01-15-2010, 08:25 PM   #1
57larry
Bellhouse Holes
I want to convert my 72 auto to a stick, I'm looking at a bellhouse from another 72 but noticed the the top 2 holes are threaded but the bottom 2 holes are smooth. how do you bolt the tranny in?
57larry is offline   Reply With Quote
Old 01-15-2010, 09:42 PM   #2
rick0312
rick0312's Avatar
Re: Bellhouse Holes
the top thread into the bell housing and the bottom just insert through bell housing and tranny and secure with a nut. I used all grade 8 hardware.
69 C10 LWB GM 350 crate motor, 3.73 rearend
rick0312 is offline   Reply With Quote
Old 01-15-2010, 10:34 PM   #3
57larry
Re: Bellhouse Holes
great photos to get the point across. thanks! do you use the bellhousing mounts or a rear tranny crossmember mount?
Old 01-16-2010, 12:22 AM   #4
Dark Knight
Dark Knight's Avatar
Re: Bellhouse Holes
The lower two tabs on the tranny should be threaded. At least mine are...
-1967 Chevrolet Fleetside LWB- 350 V8 w/thumpr cam, NV3500, 3.08 gears, A/C, PS
-1983 Chevy Silverado C1500- 383 stroker, TH400
-1989 Chevy Silverado K1500 SWB- 5.3L swap, 700R4, 3.42 gears
-And a '66 Ford Mustang- 200 I6, C4 trans, rust bucket
"The only thing we have to fear is fear itself." -FDR (and maybe rust too)
You've gotta be able to stop and steer before you can go fast!
Dark Knight is offline   Reply With Quote
Old 01-16-2010, 06:40 AM   #5
Blazer1970
Blazer1970's Avatar
Re: Bellhouse Holes
Yup, on the SM465 trannies of this era, the bottom two bolts go through from the inside of the bell housing and thread into the tranny. Later 465s did not have the holes threaded in the bottom, so you would have to use nuts to mate that combination.
Blazer1970 is offline   Reply With Quote
Old 01-16-2010, 11:59 AM   #6
57larry
Re: Bellhouse Holes
I'm going to run a 4 speed, saginaw or muncie, so I guess i'll use the bot & nut
what do you run: a tranny crossmember or the bellhousing mounts?
Old 01-16-2010, 08:29 PM   #7
57larry
Re: Bellhouse Holes
anybody?
Old 01-16-2010, 09:49 PM   #8
69 longhorn
Re: Bellhouse Holes
You can run the auto trans crossmember &mount under the saginaw or Muncie trans. Also be aware that the 72 truck bell has a centerhole size of 5.126, & the car trans needs to pilot on a 4.683 centerhole. You have a couple options on this tho....you can swap the front bearing retainer from a saginaw(truck) 3 speed , to the Saginaw 4spd. You can also opt for a 67 or older bell to center the car trans properly. Best of luck,& have fun....crazyAL
http://community.webshots.com/user/hotrodhorn
69 longhorn is offline   Reply With Quote
Old 01-16-2010, 11:08 PM   #9
57larry
Re: Bellhouse Holes
I'm confused here. what's a front bearing retainer? do you meaning throw out bearing? I have the set up from a 72 3 speed. can't I just pull the 3 speed tranny and replace it a 4 speed muncie or saganaw ? thanks
Old 01-17-2010, 12:39 AM   #10
69 longhorn
Re: Bellhouse Holes
the front bearing retainer(throwout bearingcollar,or the part that the throwout bearing slides on),bolts off the trans with 4 bolts. If you look @ the flat part of it bolted to the trans, it sticks out approx 3/16" from the face of the trans. This is how the trans centers in the bellhousing. If you have the 3spd that came with the bell, yes you can bolt the part on the front of a saginaw 4spd & all is good. The car trannyswere set up with a smaller centerhole in the bell,as were the 67 & older trucks. To use a Muncie 4spd with your bell, you will need to have a ring machined to press over the bearing retainer to properly center the trans. Or you can opt for the older truck bell(67 on back), to properly fit the Muncie. I run a 66 bell, with a 6spd ROD in my longhorn. Hope that helps,crazyAL
Old 01-17-2010, 01:21 AM   #11
rick0312
rick0312's Avatar
Re: Bellhouse Holes
I used the bell housing mounts. You'll need a pre 67 bell housing for the smaller bearing retainer. went through this myself check out thread. i posted a WTB on the board and was able to score the right bell for my 3spd man tranny.
http://67-72chevytrucks.com/vboard/s...d.php?t=292471
http://67-72chevytrucks.com/vboard/s...d.php?t=292867
Old 01-17-2010, 03:28 PM   #12
57larry
Re: Bellhouse Holes
all in all, wouldn't it just be easier to use an aluminum bellhousing and a rear tranny mount?
Old 01-17-2010, 06:04 PM   #13
69 longhorn
Re: Bellhouse Holes
I run the auto crossmember under my Richmond, & have used that crossmember under saginaw& Muncie 4spd trans in the past. Yes, I think that is the easier way,& it has not caused any trouble.....I DO prefer the cast bell made for the truck however. IMHO, you run the truck bell,& all the truck specific clutch linkage, ect & it all fits without mods to any of the linkage There are several ways you can "skin the same dern cat"......so you have to use the method that works bestest for you have fun with the project,crazyAL
