01-16-2010, 01:30 AM | #1 |
I like turtles...
how can i get the cab lower?
hey guys, i just got a 4inch z on my truck and the cab dont lay all the way in the ground, how can i get it lower without moving body mounts?
1979 Silverado- lowered 5/7, 20 inch Boss rims, everything shaved, caddy lights, billet interior, UP FOR SALE! 1983 Scottsdale-on the back burner...SOLD!!! 1992 Silverado- extended cab, stock for now, but no promises SOLD!!! 2006 Chevy Cobalt-college car, staying stock Whatever can't get fixed with a hammer, a roll of duct tape, a clothes hanger, a tube of glue, and a case of beer, can wait until tomorrow. |
01-16-2010, 06:45 AM | #2 |
67-72 parts collector,…
Re: how can i get the cab lower?
Do you have drop spindles already?
01-16-2010, 09:51 AM | #3 |
It'd be alot cooler if you did
Body drop it.
01-16-2010, 11:34 AM | #4 |
THE TOY STORE
i removed my body mounts and presto drag'n rocker.
having a badass truck and not driving it is like having a playboy model as a wife and not..... well you know. |
01-16-2010, 12:21 PM | #5 |
I like turtles...
no i dont have drop spindles, and i already took out the body mount biscuits, and how would i go about doing a body drop? ive seen it done, but not really on the 73 87s
01-16-2010, 12:27 PM | #6 |
The One And Only !!!
JR,
IMO......It would be easier/cheaper to go drop spindles and have those rear bags re-located over doing a body drop. You already have a couple nice trucks, Why all the rush on this one ?
93 Jeep XJ 88 Buick La Sabra Toys; 88 TA-GTA in the works.... 97 GMC Ext. Cab 502 Crate 5 Spd......Sucks Gas But Haulz Azz ! The primary function of an Engineer is to make it difficult for the Fabricator and impossible for the Mechanic. "Why go out preserved when you can go out beat up, worn out, sliding in sideways screaming, Holy Sh!t What A Ride" !!!
01-16-2010, 08:19 PM | #7 |
THE TOY STORE
if it is zd and lay'n frame spindals wont do anything. a traditional body drop is were you cut the floor board and let the body down lower then weld it back up. but then you gotta do the core sapport, usually by lowering the frame horns down just like you did with the z. then do the same to the bed
01-16-2010, 08:24 PM | #8 |
I like turtles...
the frame horns already are like the z, 4 inches, is there any pics of how to do the cutting of the floor? ive been thinkin about it and cant really figure it out
01-16-2010, 09:57 PM | #9 |
That's just it, His truck isn't lay'n frame the way it's zd and set up.....
01-16-2010, 11:38 PM | #10 |
gets board easy.......
id say spindles or remove body mounts
01-17-2010, 04:16 PM | #11 |
I like turtles...
i have already moved the body mounts, i think ill just cut all the fenders and rockers and move them down and fill them in with metal, it will be easier then cutting the whole cab floor up
01-17-2010, 04:39 PM | #12 |
how much did you move the mounts?
don't forget about the box, too. Last edited by smashingchuck; 01-17-2010 at 04:40 PM. |
01-17-2010, 10:29 PM | #13 |
THE TOY STORE
no it will not raising the floor is alot easier and time saving in the long run
01-17-2010, 11:04 PM | #14 |
I like turtles...
how would i go about doing it tho?
01-19-2010, 05:54 PM | #15 |
Section the frame under the cab. If you are laying frame, the frame section under the cab should be lowest part of the frame now. Cut about 1.5 to 2 inches from the bottom of the frame, brace and box everything up just like you did when you did your 4in z. That would eliminate the need to do a body drop. Now your pinch weld will be the lowest part of the truck.
01-19-2010, 10:57 PM | #16 |
THE TOY STORE
go to streetsourcemag.com and look around in there forums. there are countless bodydroped trucks there and a million pics
01-22-2010, 08:50 PM | #17 |
I like turtles...
ok i think i kno what ill do, i think ill cut the cab floor on the outside of the frame so i wont have to deal with the body mounts, keep the floor where it is, but cut the rockers out and the firewall and the back wall and section it, heres a pic that might help what im trying to say
just cut on the dotted line
1979 Silverado- lowered 5/7, 20 inch Boss rims, everything shaved, caddy lights, billet interior, UP FOR SALE! 1983 Scottsdale-on the back burner...SOLD!!! 1992 Silverado- extended cab, stock for now, but no promises SOLD!!! 2006 Chevy Cobalt-college car, staying stock Whatever can't get fixed with a hammer, a roll of duct tape, a clothes hanger, a tube of glue, and a case of beer, can wait until tomorrow. Last edited by jrsmith_2010; 01-22-2010 at 08:50 PM. |
01-22-2010, 09:00 PM | #18 |
Well that covers the cab, but don't forget you will have to do the same thing to the core support and bed.
I don't know why you aren't just modifing the frame. It's way less work, and just gets rid of all the head aches of a body drop. |
01-22-2010, 09:03 PM | #19 |
I like turtles...
i just dont get the concept behind it, is that how u did urs?
01-22-2010, 09:19 PM | #20 |
no, my truck only has a 1.5" raised front cross member.
The concept is you hack off the amonut of frame that is keeping your cab from touching the ground. Usually aronnd 1" off the bottom, then box the remainder. The you won't have to make any mods to the cab, box, or core support. And get those pucks back between the cab and the frame otherwise you are going to have problems lining everything up just like you would with a traditional bodydrop. look here: http://67-72chevytrucks.com/vboard/s...=324997&page=5 Last edited by smashingchuck; 01-22-2010 at 09:35 PM. |
01-23-2010, 01:03 AM | #21 |
ya i would remove the bottom portion of the frame thats preventing you from laying body, as stated above. see link above, page 7 and 8 shows you what to do.
[PROJECT] FnLow69- 69 C-10 Full frame & layin' doors [PROJECT] Laidout53 - 53' Dodge Pickup, Full Kustom Build [PROJECT] "Hot Rod" 1931 Model A Bonneville style "Dream as if you'll live forever, Live as if you'll die today" ~ James Dean |
01-23-2010, 02:04 AM | #22 |
I like turtles...
ok i see how its done now, but dv8 only did a 1.5 inch z where i did 4 inch, i dont need to take that much of the frame off, so im wondering if all that work is worth the 1 inch that i need to lay pinch weld, and 1.5 to lay rockers
01-23-2010, 09:15 AM | #23 | |
Yup I was just about to say the same thing. Here are a few pic taken from Brown Bag Special
Adam M STX Designs Motorcycles | Choppers | Hotrods |
01-23-2010, 11:46 AM | #24 |
Probably a little late to question that giant 4" z you did.
01-23-2010, 02:38 PM | #25 |
Happy to be here
It wouldn't help if you did. He was too set on doing it to listen to any voice of reason.
Follow me on Facebook and Instagram @N2trux.com Articles- "Jake" the 84 to 74 crewcab "Elwood" the77_Remix 85 GMC Sierra "Scarlett" "Refining Sierra" Last edited by N2TRUX; 01-23-2010 at 08:03 PM. |
