Never Satisfied
Totalled '73 4X4 Blazer
On New Years Eve a yoyo decided to come into my lane and run me off the road. I know the Blazer is rust bucket but it is mine. The rear end has been torn loose and the frame is bent.
Here is the question. I have a friend that has a '67 large window cab that is solid. New in box front clip metal. My thought is to use a '88 step side bed. Will this body fit on my '73 frame. I will post pics when I am able. It says I am missing a security token. |
Re: Totalled '73 4X4 Blazer
K5's have a 108" wheelbase I think. And SWB are 117.5....Plus if the K5 frame is bent why use it.
06' GMC 1500 Crew cab..... |
I could use some door parts from the '73 if you do any parting out on it!
Low & Fast!
Ya your blazer frame is not the same from the seat back as a pick up and it's not as long as a SB truck.
huh ???
73-91 k5 has 106.5" wheelbase...
90 Blazer Silverado 350w/ 700R4 and 32" Kelly's "I am a bomb technician. If you see me running try to keep up!" |
Never Satisfied
dang that sucks. i have a four inch supension lift, big wheels and tires and was hoping to use them instead of selling them at a loss.
if it had worked it would have been one bad '67 step side 4x4. |
In the Forgotten far North.
![]() Join Date: Jul 2007
As meatloaf said in the movie "ROADIE" Anything'll work if ya let it.
1987 R3500 CREW CAB DUALLY (BIG RED)Acquired 06/12/2015 1990 chevy suburban V2500 5.7L My cluster Mods-Nov 2007 overhead console Stereo install Round 2 Aug 2009 Heated/turn signal mirror upgrade |
Keep your lift and tires, find a different chassis and swap the parts. A '67 cab and a '88 box are not going to directly bolt onto the same chassis, so get something with a wheel base that is close and make it what ever you want.
I can still count my vehicles on two... wait three hands. |
I didn't say it can't be done....Why start with a bent frame. I would swap the lift on to a better frame.....My.02
