"THE GREEN GOBLIN"
My new exhaust system
Heres some pictures of my new exhaust system it truned out good just needs to be redone alittle around the cut out on the passenger side so I can add a small turn down. I will take some side pictures when I get a chance for some reason I forgot. I wanted something different then what everyone else is doing, I allready know half of you like to criticize & will have not so nice cool things to say about it so here ya go have at it....Try to be nice. I have abig block & you don't....
![]() "THE GREEN GOBLIN" 1972 Cheyenne 10 Short Fleet Side Front 2.5inch Spindles with 2inch Springs Rear 4inch drop Springs. 454BBC TH400,Posi 1971 Cheyenne 10 Long Fleet Side 454BBC TH350,Posi ![]() Drive it like you stole it! ![]() Petey-pablo@sbcglobal.net Last edited by petey-pablo; 01-16-2010 at 01:37 PM. |
"THE GREEN GOBLIN"
Re: My new exhaust system
Looks good... I like the sound of a single exhaust better then duals.
You might have a problem scraping though (especially if truck is lowered). I had long tube headers but changed them and ran thru the frame crossmembers.. Can't imagine how scary loud it is with the cut-outs open. Now you just got to work on flaps so you can open them from inside the cab ![]() |
dazed and confused
i think it looks good. i would love to hear it.what kind of muffler is that?
members met: redbaron69, billsbowtie,nc67 |
Next you need to upgrade to an extended bowl toilet...
1968 LWB C20 / AC / Wood Bed |
I'm probably going with a single on a new motor. More scavenging, smoother sound, less weight. I also won't have to spend a fortune on two e-cutouts. And regardless the chevy firing order is boring. People think it's terrible to do a single, but they came with them.
'72 cheyenne super step, '05 long bed gmc |
![]() Join Date: Jul 2009
Looks good bro
1972 SWB Medium Olive South Houston Instagram: Antbish84 |
i think that looks good, nice and clean, and definelty different.
James 1968 GMC "HAVOC" 1986 GMC "Frank" J.J.R.H. Design & Consulting My 68`Rebuild "HAVOC": http://67-72chevytrucks.com/vboard/s...d.php?t=316300 A 58' chev build thread: http://www.67-72chevytrucks.com/vboa...d.php?t=311238 1969 Camaro Pro Touring http://67-72chevytrucks.com/vboard/s...61#post3513361 Swiss Cheese: http://67-72chevytrucks.com/vboard/s...d.php?t=384390 Adjustable Trailing Arm How-To: http://67-72chevytrucks.com/vboard/s...d.php?t=321100 1968 Ford Farm Truck: http://67-72chevytrucks.com/vboard/s...=1#post6555587 |
I had a set of cutouts along time ago that were controlled by cables, that set is so much nicer. The system looks good. What diameter did you use? What type of muffling unit did you use?
67 blue step side- bb 68 gold and white swb cst anniversary 68 custom swb hot rod Ls swap 69 swb cst 6 cylinder/ overdrive 69 black/black cst bb swb 70 orange and white cst Canada built truck swb bb 71 black and white super swb bb 71 red and white super swb 72 green and white super swb 4x4 62 nova wagon 400 series Ls swapped 68 Camaro 327/4 speed- 1 owner, original paint 66 Volkswagen bettle 69 auto stick Volkswagen Beetle |
![]() Join Date: Feb 2003
right on! nice work
1971 K5 CST Blazer 1965 Chevelle Malibu 283 (sadly sold) 1968 Camaro 327 1968 Honda mini-trail z50a #377 1966 uh 1-D Huey |
PROJECT 7DEUCE
![]() Join Date: Dec 2002
Looks pretty nice congrats..
GO BIG GREEN ![]() MEMBER #6377 72 k-5 daily driver 6'' lift 35'' 350-350-205 slowly getting rust free. Project "7DEUCE" check out my build http://67-72chevytrucks.com/vboard/s...d.php?t=267665 Tim Powell..R.I.P EastSideLowlife..... R.I.P.. |
"THE GREEN GOBLIN"
I went with mandrel bent 3 inch pipe The muffler is by bullet performance http://www.bulletperformance.com/ ProTurbo Round Muffler...
Some more pictures from the side...These pictures are at an angle half way in and out of my garage so it looks lower than it really is.. ![]() ![]() ![]()
![]() "THE GREEN GOBLIN" 1972 Cheyenne 10 Short Fleet Side Front 2.5inch Spindles with 2inch Springs Rear 4inch drop Springs. 454BBC TH400,Posi 1971 Cheyenne 10 Long Fleet Side 454BBC TH350,Posi ![]() Drive it like you stole it! ![]() Petey-pablo@sbcglobal.net Last edited by petey-pablo; 01-16-2010 at 08:41 PM. |
#13 |
"THE GREEN GOBLIN"
Heres some on level ground.
![]() "THE GREEN GOBLIN" 1972 Cheyenne 10 Short Fleet Side Front 2.5inch Spindles with 2inch Springs Rear 4inch drop Springs. 454BBC TH400,Posi 1971 Cheyenne 10 Long Fleet Side 454BBC TH350,Posi ![]() Drive it like you stole it! ![]() Petey-pablo@sbcglobal.net Last edited by petey-pablo; 01-16-2010 at 07:48 PM. |
#14 |
I just reread my post, I meant the set you have are nicer than the junky one I used, they clattered and clanged all the time, sounded like a farm tractor with a flapper on the exhaust.
#15 |
LOL. Good eye. More unit clearance is always a plus when it comes to seat time.
#16 |
What headers are you running
#17 |
"THE GREEN GOBLIN"
They are some not so expensive, Full-Length FlowTech Headers I bought from summit. Summit Part Number BIG-31530FLT http://www.summitracing.com/parts.aspx?sku=BIG-31530FLT
"If I ever have the money" I will upgrade to something better.
![]() "THE GREEN GOBLIN" 1972 Cheyenne 10 Short Fleet Side Front 2.5inch Spindles with 2inch Springs Rear 4inch drop Springs. 454BBC TH400,Posi 1971 Cheyenne 10 Long Fleet Side 454BBC TH350,Posi ![]() Drive it like you stole it! ![]() Petey-pablo@sbcglobal.net Last edited by petey-pablo; 01-17-2010 at 01:37 AM. |
#18 |
I planed on running those too or the summit brand but am worried about how low they hang. were i live we have pot holes and speed bumps everywhere
#19 |
"THE GREEN GOBLIN"
Yes they do sit low I wish they were a few inches shorter. Plus I think I need shocks up front its too bouncy when I am going down the freway.I hate hitting those low dips.
![]() "THE GREEN GOBLIN" 1972 Cheyenne 10 Short Fleet Side Front 2.5inch Spindles with 2inch Springs Rear 4inch drop Springs. 454BBC TH400,Posi 1971 Cheyenne 10 Long Fleet Side 454BBC TH350,Posi ![]() Drive it like you stole it! ![]() Petey-pablo@sbcglobal.net |
