01-16-2010, 03:52 PM | #1 |
What welder??
I'm in canada remember so we dont have stores you do, or get as good shipping as you do, but here goes:
So I'm going to start fixing my truck up in the spring/summer of this year and i was going to buy a mig welder and start messing around now so i can get decently good when the time comes. i was going to go with either a lincoln or a miller, cant find hobarts here, and any mastercraft or powerfist brand dont seem very....good for a welder. so anyone have any experiences with any, know where to get some fairly priced? i was thinking a lincoln mig 140, or anything that plugs into a household outlet and can weld steel decent. found one at canadian tire for $649, same at princess auto. there are cheaper ones but i dont want to go with a no name welder. im wondering as well, can you use mig to weld a frame, like the truck frame or would i need stick for that? |
01-16-2010, 05:17 PM | #2 |
Re: What welder??
i have a Lincoln 135plus and i love it, have had it for about 5 years (140 was not out yet). if you are wanting a 120v unit the 140 will be an excellent unit for your needs. i think it's the best 120v welder on the market price-wise and performance-wise.
-02 avalanche (daily driver) -66 gto ragtop 389/400 (garage queen, hand-me-down from dad) -72 Tribute Trans Am (6.0LS/T56 6-speed) in progress -2003 YUKON (Wife's) -71 gmc swb fleet (current project, gonna shave everything, bags, stuff w/ 20's, gen III powertrain) -48 3100 SWB - 12/31/23 LONG TERM Project Last edited by lofly'a; 01-16-2010 at 05:19 PM. |
01-16-2010, 06:14 PM | #3 |
Re: What welder??
go to air liquid or prax air or acklands they can help you out, i deal with air liquid. Get a miller, 180 autoweld, it is 220, small light and can weld 3/16" for what you want it will be great, and automatically adjusts for steel thicknesss and runs arount 1 grand our price.
James 1968 GMC "HAVOC" 1986 GMC "Frank" J.J.R.H. Design & Consulting My 68`Rebuild "HAVOC": http://67-72chevytrucks.com/vboard/s...d.php?t=316300 A 58' chev build thread: http://www.67-72chevytrucks.com/vboa...d.php?t=311238 1969 Camaro Pro Touring http://67-72chevytrucks.com/vboard/s...61#post3513361 Swiss Cheese: http://67-72chevytrucks.com/vboard/s...d.php?t=384390 Adjustable Trailing Arm How-To: http://67-72chevytrucks.com/vboard/s...d.php?t=321100 1968 Ford Farm Truck: http://67-72chevytrucks.com/vboard/s...=1#post6555587 |
01-16-2010, 06:30 PM | #4 |
Re: What welder??
I don't think you can go wrong with either miller or lincoln, also I'd suggest that you get a gas and switch to solid wire as $$$ permit, welds are cleaner and a bit easier to work with especially for metal patch work welding thin metal.
don't know if this is true or not but I keep hearing that entry level welders sold at welding supply stores are of higher quality, you might want to look into that.
72 Chevy C20 Longhorn 72 Chevy, K20 Custom Camper 67 Chevy, LWB, C20, 350/350, PS, PB, 65 Jag MKII |
01-16-2010, 07:02 PM | #5 |
Re: What welder??
I have 2- Miller 130's and a 250 and like them all very much, and use the bottle if you can. Both brands are good machines.
01-16-2010, 07:10 PM | #6 |
Re: What welder??
yeah i think the miller 180 i was looking at from prax air was about 800 or something. and he had one in stock, i just didnt know if that was good or not.
01-16-2010, 07:19 PM | #7 |
Re: What welder??
northerntool.com has hobart 140 (made by miller i've heard) for $450 w/ free shipping to US.
if you can spring for a 220v modelk then I would do it. Mig can weld frames but you need one with decent amperage...
The Garage: 1968 K-10 SWB - "Project Money Pit" 1996 Z-71 - "huntin rig" 1969 C-10 LWB (SOLD) "Project flip that truck or else" 1993 Passport, F@rd 1-ton (SOLD)"Project Cousin Eddie" My Garage Build "The 1,000 footer" |
01-16-2010, 07:41 PM | #8 |
Re: What welder??
i wouldnt be able to plug it in though
unless i get a generator or something |
01-16-2010, 07:54 PM | #9 |
Re: What welder??
you can run 220v yourself right? I just did.. cost me $10 for the new breaker and 50ft of 12-2 wire to the garage, add $10 for a plug and box and you're done.
01-16-2010, 08:05 PM | #10 |
Countdown Survivor
Re: What welder??
Yeah, I ran 220 myself too. Plenty of how to's on the net.
I suggest getting a 220 machine also, and using the gas too. ESAB makes a good machine, if you look at used ones, ESAB used to be L-tec, and they both use the same consumables, I'm pretty sure.
93 Yukon 89 Silverado Z71 SWB Sport 91 K 2500 Silverado "Lobuk-Worktruk" A MAN OF HONOR DOES NOT LIE, CHEAT, OR STEAL, NOR TOLERATE THOSE WHO DO. Gettin' old ain't for sissies. |
01-16-2010, 08:07 PM | #11 |
Re: What welder??
Details? Pics? Links? I'd like to do this myself. Did you run it underground?
1968 LWB C20 / AC / Wood Bed |
01-16-2010, 08:17 PM | #12 | |
Re: What welder??
hope you don't mind the thread highjack, but it relates to welder choices as well... 220V is easy though, a double pole breaker (two switches) touches both legs of 110v in your breaker box. You hook up black and white wires to the switch (two screws) and the ground to the neutral ground bar. Now you are pushing 110 in the black wire and 110 in the white wire, the ground is the return line. Normal wiring is 110v on black and white is the neutral return line. If you are going more than 20amp (air compressor) then you should use 10-2 wire and a 30 amp breaker.
The Garage: 1968 K-10 SWB - "Project Money Pit" 1996 Z-71 - "huntin rig" 1969 C-10 LWB (SOLD) "Project flip that truck or else" 1993 Passport, F@rd 1-ton (SOLD)"Project Cousin Eddie" My Garage Build "The 1,000 footer" Last edited by msgross; 01-16-2010 at 08:19 PM. |
01-16-2010, 10:49 PM | #13 |
Re: What welder??
can someone tell me if this is a good welder? will it do a good job on the cab panels? i can use stick for the frame (if that works) i just want a good welder for the cab panels and stuff,
http://www.homedepot.ca/webapp/wcs/s...k=P_PartNumber now correct me if im wrong but its better for a mig welder for body panels as opposed to flux core? or is flux core equally as good? this lincoln welder is flux core ready out of the box apparently, so theres shielding gases in the wire im assuming. is this good for body panels and tack welding? Last edited by energiesource; 01-16-2010 at 10:54 PM. |
01-16-2010, 11:19 PM | #14 | ||
Countdown Survivor
Re: What welder??
The other choice is solid wire, used with a shielding gas. This will produce a very nice weld, with minimal cleanup. This is the choice of many people who use MIG for body panels.
93 Yukon 89 Silverado Z71 SWB Sport 91 K 2500 Silverado "Lobuk-Worktruk" A MAN OF HONOR DOES NOT LIE, CHEAT, OR STEAL, NOR TOLERATE THOSE WHO DO. Gettin' old ain't for sissies. Last edited by TennesseeZ; 01-16-2010 at 11:20 PM. |
01-16-2010, 11:49 PM | #15 |
Re: What welder??
I'd get one that's ready for gas...
