resident wrencher
speedo odo help
if my speedo reads 5 mph faster than i am atctully going how far off shuld my odometer be and how much will thiss effect my gas milage ? the truck has 3.07s stock and the stock tire size is 235 75 15 and now im running 31 13.5s
#2 | |
Re: spedo odo help
Not much. Think 5 miles an hour isn't much considering you have either a 15 or 20 gallon tank.Using the 20 gallon as a reference and ease of math, and also note since a 20 gallon can never be filled to 20 gallons, this is a theoretical equation to give you an idea) At 55 mph you are actually doing 50, 10 mpg at 55 (really 50) means you have 200 miles on a 20 gallon tank(50 miles per hour means you are burning 5 gallons of fuel each hour at 10mpg), so it is only a total of 20 or so miles off, or roughly 1 mpg. (20 miles divided into the 20 gallons you had=1mpg difference for each 10 miles per gallon) In reality, just the way the stupid wind blows against my trucks changes my mpg ratings....
-Josh "Mr. Simpson, there are thousands of people like you with no discernible talent." Duff World Records Division "Yeah, they're called Congress!!" -Homer Simpson Last edited by ToughBowtieTruck; 01-16-2010 at 05:31 PM. |
resident wrencher
Re: spedo odo help
thanks josh
Re: spedo odo help
I doesn't affect your actual fuel economy at all; only the way you perceive it because of calculating it off your odo.
K
Chevrolet Flint Assembly 1979-1986 GM Full Size Truck Engineering 1986 - 2019 Intro from an Old Assembly Guy: http://67-72chevytrucks.com/vboard/s...d.php?t=342926 My Pontiac story: http://forums.maxperformanceinc.com/...d.php?t=560524 Chevelle intro: http://www.superchevy.com/features/s...hevy-chevelle/ |
