Old 01-16-2010, 04:21 PM   #1
The Big Green
Need help with rearend axle swap
Well I have a '67 with a 71-72 5lug rearend swap. I have a 4link and it's too hard to cut, align and reweld new brackets on a 6lug rearend. I want 6x5.5 pattern for a better choice of bs wheels. I heard that I can swap backing plates and axles from a 67, which a guy I know has and get my rear 6lug while gaining 3/4in wheel room. Is this true?
The Big Green is offline   Reply With Quote
Old 01-16-2010, 04:41 PM   #2
john
member #16
john's Avatar
Re: Need help with rearend axle swap
The 67 axles are shorter than 71-72's Some 1970 models have the longer six lug axles,
john is offline   Reply With Quote
Old 01-16-2010, 04:47 PM   #3
The Big Green
Yes, I know that the 71-72 are 1.5in wider. I heard that swapping my axles and backing plates for 67-70 ones and making it 6lug and also 1.5in narrower than I am now.
Old 01-16-2010, 05:03 PM   #4
john
member #16
john's Avatar
You still have the longer 71-72 housing. Sometime during the 1970 year gm went to the same housing as 71-72. Without custom axles , the1970 six lugs are the only bolt in's that will work. Some people have used the later backing plates and drums to use 71-72 axles in the early shorter housings.
Old 01-16-2010, 05:05 PM   #5
cdowns
cdowns's Avatar
the shorter axels dont fit in the longer housings it doesnt matter what backing plates you use
THEY DONT FIT
Old 01-16-2010, 06:05 PM   #6
Zeke
Active Member
Would 71-72 4x4 axles fit? They stayed 6 lug.
1969 C10 350 3spd
1995 GMC 3500 XC 350 dually
When Thomas Edison worked late into the night on the electric light, he had to do it by gas lamp or candle. I'm sure it made the work seem that much more urgent. George Carlin
Zeke is offline   Reply With Quote
Old 01-18-2010, 12:12 AM   #7
lolife99
67-72 parts collector,…
lolife99's Avatar
No.
This is incorrect.
lolife99 is online now   Reply With Quote
Old 01-18-2010, 03:51 AM   #8
The Big Green
Will 73+ 4x4 axles fit? Heard that too lol.
Basically what are my options here? I need 6lug and I need higher than my 4.11 gears. I'd have someone cut the brackets and install a different rearend but I just don't really know. I could redrill the pattern if I can but in a way that 3/4in would be a nice little gain.
Old 01-18-2010, 08:04 AM   #9
Zeke
Active Member
Pretty sure 70-81 4x4 would fit. 0.031 shouldn't make a difference
http://www.drivetrain.com/parts_cata...s.html#GMTRUCK
14071750
70-81 BLAZER, JIMMY, SUBURBAN, PICKUP, 1/2-TON 31-9/32'
6 Lug
30 spline
8.875"
$130.23
14071751
71-81 BLAZER, SUBURBAN AND PICKUPS 31-5/16"
5 Lug
30 spline
8.875"
$130.23
1969 C10 350 3spd
