01-27-2003, 07:11 PM | #1 |
Project 7dos
Demon CARBS<<<<<<
Well we got the motor back in the truck yesterday(Flat Cam) anyway, we went with our Demon 650 Cfm carb. Well we put it in and it just keeps backfiring through the carb....What the heck is wrong with it?? We set the time and moved it around but nothing. What do you think???
Holly Street Avenger???? Best way to go maybe..... Thanks Jason
7DOS - 1972 C-10 350/350 Porterbuilt/Accuair 20x8.5/20x10 Ride Low or Die PSSST - Yes it's bagged. 7dos build thread: http://67-72chevytrucks.com/vboard/s...d.php?t=610290 |
01-27-2003, 08:27 PM | #2 |
Used to have a truck
unless youve got the fuel level WAY too high backfiring though the carb isnt the carbs fault. Make sure your ignition timing is where it should be ( after verifying your float level ) ...Then its on to rocker arm setting ( likely ) or cam setup.
BTW cams dont just go flat without some help . What happened ? Are you sure your not repeating the mistakes that caused the flat lobe?
No truck :-( Last edited by mikep; 01-27-2003 at 08:36 PM. |
01-27-2003, 08:45 PM | #3 |
what kind of intake are you running?..might be a vacuum leak..if you have a performer without an adapter. this can be a problem
Jim
It's called "drag racing" if they called it "tic..tic..WHAM!..BANG! F*&K!!!", they'd have to keep the magazines under the counter with the other men's publications click the clicky to join the site.... http://67-72chevytrucks.com/vboard/payments.php 67 lwb..first hotrod in 25 years..540 best ET is 9.45 @ 141.44 Anderson,CA |
01-27-2003, 09:19 PM | #4 |
Double check your firing order.. its easy to cross 5 and 7. It will cause it to run a bit rough but also backfire through the intake.
01-27-2003, 09:23 PM | #5 |
Might also check that the distributor isn't 180 degrees off.
01-27-2003, 09:24 PM | #6 |
Location: Bondurant, IA but in Worcester, MA for school
THis same thing was happening to me when I put my new HEI distibutor in. My timing was way retarded...check that again.
HotRod
1970 Chevy C-20 350 V-8 Turbo 350 w/ shift kit Dana 60 w/ 4.10 gears AND Powr-Loc POSI New Additions: Summit Headers 135amp alternator Proform HEI Edelbrock 1406 600cfm carb Sunpro Tach Powr-Loc POSI Edelbrock Performer RPM Intake MSD 6A Ignition Box AIM: HotRod929 Visit My Site: http://1970chevy.netfirms.com/ |
