I'm changing out the brake cylinders (drums all around) on the front of my truck. Anyone have a tip on how to free up the bolt that secures the front wheel cylinders (also the pivot stud for the shoes)? I went and bought a 1-1/8 socket a breaker bar and they aren't budging. I don't have an impact wrench and don't want to strip them off. Am I doing this right? Does the whole thing come loose? Cnut
Re: help with a front brake cylinder mount bolt
on old rusty brakes i've just tightened and snapped off the heads on the cylinder mounts and then used new bolts to mount the cylinders// never had any need to remove a pivot pin so dont know
I am a Referee of life.
Me neither but if I were to try to remove one the first thing I would do is use a real penetrating oil.PB Blaster,Kroil or equivelent.Contrary to popular belief WD-40 is not a penetrant.The WD stands for water dispersant.Then the breaker bar and socket may budge it or not.
The 47-present Chevrolet and GMC Truck Message Board Network,it's owners,moderators,members,and associates of any type should not be held responsible for my opinion. You can't fix stupid,not even with duct tape. "My appearance is due to the fact that "GOD" does punish you for having too much fun!" Barrett-Jackson has perfected alchemy,they make rust into gold! "You can lead a horse to water but you can't saddle a duck" "Cleverly disguised as a 'Responsible Adult' "Sometimes your Knight in shining armor is just a retard in tinfoil" |
Sisyphus was my mentor!
![]() Join Date: Sep 2002
I used a breaker bar, some heat & a little lube. I heated it up for 5 minutes with my propane torch, shot it with spray & put the bar on it... It went "click" & it was loose.
passthebuck ![]() #5642 -TWO 1967 GMC 910's. One with L6/3-on-the tree and the other with 355 w/435hp & a 700r4. -a 2013 Honda Civic as my "sensible" car |
The Older Generation
I always use heat on stubborn fasteners. Before I got my Acetylene torch I used a Mapp Gas torch with some success. On the bigger stuff it won't produce enough heat though. LockDoc
Wow, thanks for the quick replies. The heat thing is a good suggestion. I can get that in the morning. Cnut
Chemist under the hood...
I had the same problem. I tried the breaker bar and it wouldn't budge. I didn't have a big enough compressor for the impact wrench so I bought a 7.5A electric impact gun. Worked like a charm. Well worth the $40. Works great on wheel nuts etc.
Current fleet: 2013 GMC Sierra, 5.3L, 4x4 1988 GMC Sierra, 305, Auto 1984 Jeep Grand Wagoneer, 360 V8 1997 VW Cabrio, 2.0L 2017 Toyota Rav4, 2.5L Stuff I wish I still had: 2013 Toyota Matrix [RIP] 1967 GMC 910 Fleetside, 283 V8 [1st Love-SOLD] 1987 Jeep Cherokee Laredo 4X4, 4.0 I-6 [SOLD} 1994 Chevrolet Caprice Classic, 5.7LV8 [SOLD] 1995 Chevrolet Astro AWD, 4.3L V6 (RIP) 1998 Chevrolet Suburban 4x4, 5.7L V8 [SOLD] |
Tried the torch approach to no avail. In the morning I'm going to the Auto craft shop (one of the perks of the military) I'll be able to use the impact wrench, and hope it works. Thanks again for all the input. Cnut
Done!
![]() ![]() ![]() Last edited by 70Custom10Nut; 01-17-2010 at 05:15 PM. Reason: grammer |
Glad it worked out. When I got my truck, it had 1 seized cylinder on the front and one on the back. After I replaced all four, two new drums, all new shoes, it was a different stopping experience to say the least. A lot of people on here replace the front drums with disks. It has a gas tank in the cab, manual steering and manual brakes so I don't think the four drum brakes are the biggest issue!
I seriously considered the front disc option, and for the longest time it was going to be "the next big thing I buy for the truck". But then I looked at the justification. I've only put 8000 miles on her since the power train rebuild in 1999, I only drive her about three days a week, and I don't tow anything. Besides the drums do a pretty good job when I hit the whoa pedal. Maybe some day in the future, but I'm happy with it for now. Cnut
