Old 01-16-2010, 11:53 PM   #1
JimmyFloyd
Are blazer and suburban gas tanks different?
So I have a 70 blazer and a 70 suburban. I need a new tank for my blazer, and the one on the suburban is good. I would like to use it, but was wondering if they were different? It seems that the suburban one has a indentation running across the top of it like it's meant to fit around a crossmember.
So are they actually different and will it fit?
1970 Blazer 350/SM465/205 SOLD! | 1998 Z3
JimmyFloyd is offline   Reply With Quote
Old 01-17-2010, 12:26 AM   #2
JimmyFloyd
Re: Are blazer and suburban gas tanks different?
This is the Suburban gas tank. You can see it on the bottom of the picture.
Old 01-17-2010, 12:30 AM   #3
63chevyll
gets board easy.......
63chevyll's Avatar
just yank it. it should work. I dunno for sure but wont hurt to try?
63chevyll is offline   Reply With Quote
Old 01-17-2010, 09:41 AM   #4
swyfor5
swyfor5's Avatar
My 1970 K5 has a tank out of a 1972 2wd burb in it. Worked just fine!
swyfor5 is offline   Reply With Quote
Old 01-17-2010, 02:12 PM   #5
Frankie Humphries
i think in the lmc mags, the suburban tank is a gal bigger.
If you're not first, your last!
Frankie Humphries is offline   Reply With Quote
Old 01-17-2010, 05:11 PM   #6
BIGBLU 72
BIGBLU 72's Avatar
My Jimmy has an 72 burn tank in it! The filler neck is a little diff but they will work
68 C10 LWB 2/4 drop 406/th400/3.73posi
04 Silverado SS LQ9 6.0/4L65e/4.11posi AWD
BIGBLU 72 is offline   Reply With Quote
Old 01-17-2010, 05:17 PM   #7
JimmyFloyd
Good. This is what I wanted to hear. I have a 90 blazer 31 gal tank I want to use when I finally get it assembled, but I'd like to use this while I am working on the other stuff so I can move it around the garage. The drivetrain works fine, Just off a gas can, so I'd rather have a factory tank instead of the can.
Old 01-17-2010, 05:21 PM   #8
JimmyFloyd
Hrm... Looks like i am going to look at something like this for cleaning the inside of the tank: http://www.por15.com/FUEL-TANK-REPAI...ductinfo/FTRK/
