Old 01-17-2010, 12:13 AM   #1
Big-Blue
Big-Blue's Avatar
Can I spray epoxy primer over rattle-can paint
I have a new set of springs which are probably rattle can painted from the spring company. I have had them for about six months and needless to say, the paint wasn't great when I got them and is worse now due to me moving them around, installing, etc. Can I scuff them and shoot PPG Epoxy and a PPG top coat without worry?
Big-Blue is offline   Reply With Quote
Old 01-17-2010, 12:34 AM   #2
Bus Ted Knuckle
Son of a gun
Bus Ted Knuckle's Avatar
Re: Can I spray epoxy primer over rattle-can paint
sure but don't expect it to hang around too long, it will only be as good as what is under it.
BEATERS ARE NEATER
Bus Ted Knuckle is offline   Reply With Quote
Old 01-17-2010, 12:52 AM   #3
63chevyll
gets board easy.......
63chevyll's Avatar
what he said......Unless all the factory paint is gone (sand blasting, ect) they will look good for a while, but eventualy problems will come through
63chevyll is offline   Reply With Quote
Old 01-17-2010, 11:06 AM   #4
mbgmike
if on the truck, to do it better I would remove them to get good coverage and cleanup. get a pint of any of the DP primers if using PPG. sand them down as best you can, clean the with a solvent, and use a single stage black ( i like Chrysler black) seems blacker to me. Maybe its just my eye
going to last about as long as it will w/o powder coating them
mbgmike is offline   Reply With Quote
