Old 01-17-2010, 02:28 PM   #1
mooseknuckles
mooseknuckles's Avatar
Air Bagged
I have a '86 lwb that's lowered 5/6 and I want to air bag it and I need some advice. What is the cheapest, easiest way to bag it, and what parts would I need? I already have 3" drop spindles and I know I have to step notch the rear. I want to be able to raise and lower it for bumps and driveways, and eventually lay frame or rocker, which would require "Z"ing the frame?
mooseknuckles is offline   Reply With Quote
Old 01-17-2010, 02:59 PM   #2
texasfunk
texasfunk's Avatar
Re: Air Bagged
you might get more help in the suspension forum, a MOD will be able to move the thread for you, there is alot of knowledge about air ride over there
2006 GMC Sierra CCSB, 6.0 swap
2000 Chevy C3500 Crew Cab shortbed dually
1999 Chevy c2500 Crew Cab shortbed
1982 El Camino 350/350
1979 K5 2wd blazer bagged/bodied
1986 Monte Carlo SS
1991 Chevy CK SWB-67 clip and tailgate, bagged 350/700r4
1955 Chevy Bel Air
2014 Chevy Silverado ccsb
texasfunk is offline   Reply With Quote
Old 01-17-2010, 06:59 PM   #3
N2TRUX
Happy to be here
N2TRUX's Avatar
Re: Air Bagged
If your on a budget start collecting parts as you can afford them. For the front you will need bags, mounting plates, and some type of valve.
The rear can be done with a Air Over Leaf (AOL), 2 link,or 4 link. Depending on how low you want to go it will require a C-notch or Step Notch.
Spend some time reading here and many of your questions will be answered in depth.
Articles-
"Jake" the 84 to 74 crewcab
"Elwood" the77_Remix
85 GMC Sierra "Scarlett"
"Refining Sierra"
