Old 01-17-2010, 02:38 PM   #1
6t727t2
Active Member
Blazer/Jimmy used custom made soft top in NJ
This soft top was made by a boat/canvas shop. I got it along with a parts Blazer, and never saw it installed. I drapped it over a Blazer top to show the way it should look, the rear looks slightly angled back as opposed to flat. The outside of the top seems to be a canvas/vinyl? material. Along with the top, included are aluminum bows and an aluminum front rail piece that the top slides through to attach. Also some chrome hasps and straps. You will need to figure out how to attach the bottom snaps to the body or fab some type of railing? The plastic sides and back seem to be in good condition and are not brittle. There is a gray streak on each side of the plastic windows that are probably from the bows rubbing against it. I show where I started to clean it off, but will let the buyer experiment with cleaning it off, no guarantees it will clean off completely. The outer fabric has a few very small 1/4 inch rubber hole repairs. The inner canvas has a few rub marks, but doesn't go through the material. The zippers are in good condition and open/close easily. Yes, this will take some work and fabrication to install, but could be a way to have a soft top at a reasonable price. $250 picked up in NJ. I would prefer you see this in person and pickup in NJ, but if you want to tackle it, I will ship it for $60. I have many more pictures, if your serious send me an email address and I'll send more pictures.
6t727t2 is offline   Reply With Quote
Old 01-20-2010, 02:14 AM   #2
robs71k5
K5drive
robs71k5's Avatar
Re: Blazer/Jimmy used custom made soft top in NJ
Hey I'd be intereseted in some more pics to ... robandsandy@shaw.ca .....Did you say there was a couple holes or just the one in the photo ? Thanks Rob
robs71k5 is offline   Reply With Quote
Old 01-20-2010, 09:02 AM   #3
6t727t2
Active Member
robs71k5, there are a few very small holes that have been repaired with rubber sealer, that picture is of the rub mark on the side window that I started to clean off, not a hole. I will email you more pictures.
Here are a few more pictures.
Old 01-20-2010, 06:53 PM   #4
TheWraith
where are you located in NJ? I'm in Allentown, PA, and I might be interested in coming to take a look.
pm me.
Thanks,
Alex
TheWraith is offline   Reply With Quote
