Old 01-17-2010, 04:49 PM   #1
harold64
harold64's Avatar
door ajustments
dos any body know if you can adjust the hidges on a 64 c10? or do i have to replace the hinge pin, what to do ect. thanks for the help. the doors seem to sag, and you have to pull the door up to close it all the way.
harold64 is offline   Reply With Quote
Old 01-17-2010, 06:20 PM   #2
markeb01
Senior Enthusiast
markeb01's Avatar
Re: door ajustments
The hinge pins may well be worn out, but you can certainly adjust the hinges. Adjustments are similar 60-66. Per the 1960 Chevy Shop Manual:
Door adjustment may be accomplished at two places; at the hinge straps to door panel and at the hinge cage to pillar. Before adjustment is made on any door, however, the striker plate and wedge should be loosened or removed. The door can be moved fore, aft, up and down at the hinge pillar and the door can be moved in and out at the hinge to door panel. Move door as required and tighten bolts to 20-25 ft. lbs.
The door should have a normal clearance of 5/32” around the entire outer lip of door except at the bottom where it should be ¼” from the door sill. The door should be adjusted in the opening so the edge of the door across the top and also at the lock side is parallel with the body opening as nearly as possible.
Old 01-17-2010, 07:53 PM   #3
harold64
harold64's Avatar
Re: door ajustments
hey there markebol! thanks for the fast response. will get a set of hidge repair kit for each door just in case. will check out adjustments when i get the " bad bowtie" back out of hibernation in the spring. thanks again, have fun, and bring on spring!
Old 01-18-2010, 01:47 PM   #4
DaddyMack
Wide Eyed User
DaddyMack's Avatar
Re: door ajustments
I am having a heck of a time lining up my doors, I am thinking of just upgrading to bear claws and be done with it... I would rather keep the stock, but....
1962 Chevy P/U SB Fleetside
350/350
2.5/5 static drop
My Build: http://67-72chevytrucks.com/vboard/s...d.php?t=294723
Final (as final can be ) Pics: http://67-72chevytrucks.com/vboard/s...d.php?t=393441
DaddyMack is offline   Reply With Quote
Old 02-23-2011, 11:04 AM   #5
ol Curt
Junior Member
ol Curt's Avatar
Re: door ajustments
I am ready to align mine and am always a bit confused. I understand which are for in/out and up/down/forward/back, but all I read seems to indicate to only loosen one hinge at a time and move it. It would seem both would have to be loose for the door to move.
What am I missing?
1966 Chevy C10 Longbed
I'm Bob....ol Curt was my Grandpa
The truck was his and he sure as heck wouldn't understand why I took a perfectly good truck and tore it down!
ol Curt is offline   Reply With Quote
Old 02-25-2011, 10:53 AM   #6
ol Curt
Junior Member
ol Curt's Avatar
Re: door ajustments
Anybody that can help me understand this?
Old 02-25-2011, 01:09 PM   #7
rideblue00
rideblue00's Avatar
Re: door ajustments
Both sets do not have to be loose. But they shouldnt be really tight. Work with one hinge at a time. I only put 2 bolts in on both halves of the hinge. I have one bolt snug and one less snug. Which allows for some movement.Its just trial an error until the door is centered. Everybody gets excited about loosening hinges. Just loosen the bolts enough to move it around and dont let it fall into the body and chip the paint. 1/4 inch gap at bottom and 1/8 to 5/32 around the sides and top. Or whatever looks centered. I have found several trucks to have a tight gap at the point where the driprail is at the edge of the windshield(64-66). Thats all i know so far.
rideblue00 is offline   Reply With Quote
Old 02-25-2011, 02:31 PM   #8
neto
neto's Avatar
Re: door ajustments
thanks for posting this information. I needed it.
neto is offline   Reply With Quote
