01-17-2010, 04:52 PM | #1 |
wicked squeal from transmission, wondering why
i just made a 900 mile trip last week from Massachusetts to Indiana and my '68 K10 ran beautifully the whole way. but after i got i got her going the next day and for about a minute or two after i get her on the road its making this nasty squealing noise when i shift through the gears and after a minute or two it goes away. i'm just wondering if its something i should be concerned with or if there is anything i can do to fix it or if it will just go away.
thanks for your help. |
01-17-2010, 05:02 PM | #2 |
Between Trucks...
Re: wicked squeal from transmission, wondering why
Sure it's the transmission and not a belt slipping?
Beat it to fit, Paint it to match... |
01-17-2010, 05:02 PM | #3 |
Car Knocker
Standard Transmission? Sounds like a throw out bearing. I would check fluid in trans just to be sure also. Noises hardly ever go away, usually will get worse as time goes on.
68 c-10,91 sportside bed,350 .030 over,4 bolt,10-1 comp,2.05 intake/1.94 exhaust,1.6 Harland Sharp roller rockers,edelbrock rpm cam and intake w/750 carb, 700r4, 3.73 gears,Jacabbs Electronic Igntion w/Accel HEI distributer and super coil. ZR-1 roll pan, filled tailights. Blazer tank. Hidden hitch. 2 1/2" Flowmaster 40's. Parts bought but not installed>> ford 9" posi with disc. CCP front and rear lowering kit 4/5. Cab corners,foor boards,rockers, cab braces, Phatom grill, Painless wiring kit. |
01-17-2010, 05:14 PM | #4 |
its all about the +6 inches
usually when they go away, is about the time you are calling for a wrecker.
01-17-2010, 05:41 PM | #5 |
i guessed transmission because it starts happening when i get her going and is worst in third gear, but i really have no idea. i think i'll start by checking tran fluid and i don't really know how to check to see if a belt is slipping significantly like that, besides if it is just really loose. i appreciate your help and if anyone has any other ideas that would be awesome.
01-17-2010, 05:44 PM | #6 |
oh yeah, i'm not familiar at all with vehicles like this, this baby is still new to me. but i'm guessing that a throw out bearing would not be easy or cheap to fix. any ideas on how to check that?
01-17-2010, 06:31 PM | #7 |
People know me
Another vote for belts, check tightness, and overall condition of them
1972 k/5 blazer CST 4X4 Crate 350, th350/205, dana44with trac-loc/14 bolt with detroit locker, 4 wheel discs 4.56s, 8" suspension lift using 73-87springs, 1" zerorate custom front crossmember, HAD CV drivelines and driveshaft e-brake, full cage, PRP seats, Full autometer gauges, 38x14.5x16 Toyo M/Ts, 16x10 Polished aluminum rockcrusher wheels 1967 longbox 4x4, Strong 400/400/208, 44/12bolt 4.10s, 6" lift, 35" Toyo M/Ts on corvette rally wheels |
01-17-2010, 06:31 PM | #8 |
Well, the throw out bearing shouldnt make any noises when the clutch is UP.....you will hear it when you depress the clutch to shift. u joints can squeal like he!! if they are on the way out....just a thought?
http://community.webshots.com/user/hotrodhorn Last edited by 69 longhorn; 01-17-2010 at 06:34 PM. Reason: more info |
01-18-2010, 02:10 AM | #9 |
thanks again for all of the help, i'm definitely going to check the belts and see what i can do. i'll let you know how it goes.
