01-17-2010, 05:12 PM | #1 |
Justified!
Door Mechanism help....
My passenger side outside door handle will not open my door.
When I looked inside the door, the push rod is shorter than the one on the drivers side. Do they have a different length for different years? I do not see a way to adjust where the push rod strikes the striker either, so I am thinking I have to buy a new handle........ Anyone else ever had this problem? 1964 GMC Fleetside.......
Chad 1964 GMC Fleetside Shortbed....350/700R4 tranny |
01-18-2010, 02:04 PM | #2 | |
Wide Eyed User
Re: Door Mechanism help....
I did! I ended up cutting the rods in half and welding them to the correct length. I had purchased new ones for the correct year, but they were long.. I am thinking of ditching the old locks and strikes for a bearclaw..
1962 Chevy P/U SB Fleetside 350/350 2.5/5 static drop My Build: http://67-72chevytrucks.com/vboard/s...d.php?t=294723 Final (as final can be ) Pics: http://67-72chevytrucks.com/vboard/s...d.php?t=393441 |
01-18-2010, 04:48 PM | #3 |
Rods
i am gion to try to use 08 chevy plates and handles.I want better handles inside
Just keepin it simple. 1965 C-10 Ext cab build. 350??(Does it count at 2 truck if I had to cut one up?) 1966 C-10 lwb 283 auto 1970 Suburban in pieces 1971 Blazer 4wd....restore someday. all factory CST 1972 Blazer 4wd parts truck still a roller 1972 GMC Sierra Grandee 1998 Chevy ext driver. 2005 F**D the wife drive...(cant fix women) |
01-18-2010, 05:44 PM | #4 |
and a few others
I know from experience if the handle isn't totally tight against the shell it won't open from the outside. Even a little loose will cause it.
Bill US Army Vet -193rd Infantry BlueRidgeMuscleCars.com “The greatness of a nation and its moral progress can be judged by the way its animals are treated” Gandhi |
01-18-2010, 09:48 PM | #5 |
Justified!
Well, I have another mechanism to put in the door, so maybe that will work, if not, I am going to try and either replace the rod, or find another handle......
I had 2 or 3 doors, and I am not positive I have the original mechanism or handle on the door...... Stuff gets mixed up over a couple of years.....
