Old 01-17-2010, 09:24 PM   #1
glider_6969
Question Headers Install clearance
Installing headers on a 350 for 68 gmc, (they are full length) can anyone tell me if they have had trouble with location of the bellcrank(Z bar) or any of the clutch linkage. Will I have to mod or move anything. The truck originally had a 250 engine in it. Any help would be great.
glider_6969 is offline   Reply With Quote
Old 01-18-2010, 01:30 AM   #2
69 longhorn
Re: Headers Install clearance
Yes, if you are using the I6 frame stands,things will be different. What brand headers do you have?
http://community.webshots.com/user/hotrodhorn
69 longhorn is offline   Reply With Quote
Old 01-18-2010, 09:56 PM   #3
glider_6969
What do you mean by frame stands ? Do you mean the frame bracket for the bell crank? Hedman Headers.
Old 01-18-2010, 10:01 PM   #4
Blackbird66
I have headers from summit racing, don't know who makes them for summit. I have no fitment issues with them. They are a little tight hear and there, and require removal of the starter to install.
Blackbird66 is offline   Reply With Quote
Old 01-18-2010, 10:18 PM   #5
glider_6969
Hey Blackbird, are yours black. I ones that I am getting are also from Summit.
Old 01-18-2010, 10:20 PM   #6
glider_6969
Summit part # Sum-G9006
Old 01-18-2010, 11:09 PM   #7
Jacfourteen
Big Red - Now its a SWB!
Jacfourteen's Avatar
I have a 350 in a 68 gmc, mounted in the 6 cyl location on the I6 stands. I'm using some cheap full length flowtechs (said they fit 67-87 chevy/gmc) that I got at O'reiley's and I had no clearance issues.
68 3/4 ton (Project)-350 Small Block, .030 over, 10:1 comp, 3998993 heads, C3BX edelbrock intake, comp cams XE268, Holley 670 SA, long tube headers, dual flow 40's, E-fan, Alum rad, currently under the knife getting shortened and bagged build thread
41 3/4 ton (wife's)-flatbed, fully restored to original
01 Tahoe LT 4WD (my daily driver)-Magnaflow Muffler, Rollin on 22's
02 Ford Mustang Convertable (Wife's Car)-Flowmaster 50, Clear corners, Intake, sittin on 18's
Jacfourteen is offline   Reply With Quote
Old 01-18-2010, 11:12 PM   #8
Jacfourteen
forgot to mention that I have the stock granny 4-speed. I have enough clearance that last time I pulled the engine I left them bolted to the motor and pulled them out with it with no problems.
Old 01-19-2010, 05:00 AM   #9
Blackbird66
I have run these since around '01 so I have no idea what the part # is, but if they are summit brand, I'm sure they have not changed.
Old 01-19-2010, 10:14 PM   #10
glider_6969
The frame mounts have been moved back so the motor is now close to the firewall, I guess I'll have to wait and see when the headers come. As many projects go if they were easy it wouldn't be right. Thanks for all the info guys.
