01-17-2010, 10:09 PM | #1 |
14 Bolt SF
Came across a 14 bolt sf out of a 87 2500 4x4.Has anybody ever swapped one into their 2 wd , are they wider then my 1/2 ton 10 bolt? Can you just get the axles drilled to 5 on 5 pattern? Searched quite a bit and never really found an answer.Maybe not even worth it in the long run i don,t know.I bought another motor for my truck and i need to get rid of the 308 open rear for sure but now i,m just confused.I have a 10 bolt in my truck,a 12 bolt posi carrier in my garage (no gears) and now this 14 bolt but not sure which way will be the best way to go
01-17-2010, 10:55 PM | #2 |
Re: 14 Bolt SF
Hey Ont Guy 38
Even if you Re-Drill axles The center Hump on the Axle probably will not fit Those nice rims you got. Your 12 bolt would be the Best Choice/ Money wise. |
01-18-2010, 12:40 AM | #3 |
Re: 14 Bolt SF
That's a pretty but diff to be putting in a 2wd. I have a 14 bolt in my 1978 k20 and its beast. I would stick with a stock one or a 12 bolt or even a ford nine inch.
01-18-2010, 01:06 AM | #4 |
Location: Where I come from, it's cornbread and chicken...
Re: 14 Bolt SF
I have a 14 bolt FF in my C20 stock...it's a good axle and won't let me down...the 14 SF is still an alright axle and will do fine in your truck...it should be the same width and bolt up just fine...the only problem is the bolt pattern is 8 lug...you could take and swap 3/4 ton control arms and spindles up front and leave your 1/2 ton springs in ...that would give you 8 lugs up front...
01-18-2010, 01:22 AM | #5 |
Re: 14 Bolt SF
i had a 14 bolt 5 lug in my 90SS, i dont know if they came in anything else, but its something to think about
2006 GMC Sierra CCSB, 6.0 swap 2000 Chevy C3500 Crew Cab shortbed dually 1999 Chevy c2500 Crew Cab shortbed 1982 El Camino 350/350 1979 K5 2wd blazer bagged/bodied 1986 Monte Carlo SS 1991 Chevy CK SWB-67 clip and tailgate, bagged 350/700r4 1955 Chevy Bel Air 2014 Chevy Silverado ccsb |
01-18-2010, 11:52 AM | #6 |
Re: 14 Bolt SF
Like texasfunk said a SS454 rear end would work for you, but may be hard to find. Though if you could find replacement or aftermarket axles for that application, score a 88-98 3/4 ton 14 bolt SF, and you could probably swap the axles and end up with what you want. I don't know that there's enough room on an 8 lug axle to drill it for 5x5.
1977 GMC Sierra Grande |
01-18-2010, 12:14 PM | #7 |
Re: 14 Bolt SF
SF 14 bolts also came in 6 lug on the light duty 3/4 tons in 88-98. Like they said 5on5 pattern is do-able since the 454SS trucks ran them but I dont know if you can just redrill what youve got to get your 5 lug.
01-18-2010, 12:47 PM | #8 |
Re: 14 Bolt SF
Don't recommend redrilling for a 5x5 pattern. From what I've seen there's not enough meat to be safe. Suggest you go 6 lug all around.....there's enough parts in wrecking yards to do this inexpensively or get a rust bucket and transfer what's needed.
01-18-2010, 02:57 PM | #9 | |
Re: 14 Bolt SF
-Josh "Mr. Simpson, there are thousands of people like you with no discernible talent." Duff World Records Division "Yeah, they're called Congress!!" -Homer Simpson |
01-18-2010, 03:48 PM | #10 |
Re: 14 Bolt SF
01-18-2010, 05:23 PM | #11 |
Re: 14 Bolt SF
It is a 6 bolt , you guys are right tho I should probably stick to the 12 bolt or the ford 9 inch.I just seen it for sale and knew that 454ss had that in it so i thought i would ask if anybody has ever done the swap to a 2 wd
01-18-2010, 07:21 PM | #12 |
Re: 14 Bolt SF
They sell 5 and 6 lug axles for the 14 bolt non FF,But I also would go with a 12 bolt!!
01-18-2010, 08:00 PM | #13 |
Re: 14 Bolt SF
No I am not. I am talking 88-98 trucks.
I have 2 1995 1500 Z-71s. One is a HD and one is standard duty. The HD has different drive shafts, engine oil cooler, 2nd trans cooler, etc. Also has the 14 bolt SF axle. And, my 1500 HD has a gvwr of 6,700. The other 1500 has a gvwr or 6,200. But they are both 6 lugs also.
-Josh "Mr. Simpson, there are thousands of people like you with no discernible talent." Duff World Records Division "Yeah, they're called Congress!!" -Homer Simpson Last edited by ToughBowtieTruck; 01-18-2010 at 08:01 PM. |
