Old 01-17-2010, 10:12 PM   #1
Envy
Envy's Avatar
CPP Drop crossmember.. Whats the secret?
I started my cpp crossmember install today, but the factory rivets were killing me. I cut the heads off the rivets with a cut-off wheel and used an air chisel to push them out. The four top rivets came out easy but the bottom eight didnt budge after an our of hammering with the air chisel. Before i take a torch to them, any suggestions?
Envy is offline   Reply With Quote
Old 01-17-2010, 10:45 PM   #2
62gmc910
62gmc910's Avatar
Re: CPP Drop crossmember.. Whats the secret?
I have had better luck cutting the rivits off with a chizle. when you grind the head off the expanded part is still on the surface. if you have ground them all I would recomend that you heat the RIVIT to red with the torch , then let it cool on its own ,go have a coffee or beer . when they have cooled they should pop out fairly easily. when you heat the rivit it will try to expand but the hole won't let it so when it cools it should shrink and come out easier, works with broken bolts too
62 GMC 910 short fleetside 454 super t10 14 bolt
w/gov lock 70s c20 front discs (built in the 80s)
65 GMC 930 dualwheel 292 4spd all origonal 39k mi(my sons truck)
63 GMC 950 camperized school bus, (Gus the bus)
350 4speed 2 speed rear
64 GMC 950 "spare" bus 283? 4speed detroit locker
53 GMC 1ton dual wheel bus
78 GMC c25 short course off road race truck(son's truck)
355 th400 14 bolt (www.wheel2wheel.ca)
88 Peterbilt 379 longhood (hauls race truck)
62gmc910 is offline   Reply With Quote
Old 01-17-2010, 10:46 PM   #3
shrunken66stroker
shrunken66stroker's Avatar
Try to heat them up and hit em with the hammer again. If not torch em. You could also drill a small diameter hole and then hammer. Are you chisling the heads off before hammering?
shrunken66stroker is offline   Reply With Quote
Old 01-17-2010, 10:48 PM   #4
Envy
Envy's Avatar
good deal guys, thanks, i thought about using the torch but didnt want to mess up the holes, but the cooling/shrinking trick is helpful. thanks again.
Old 01-17-2010, 11:35 PM   #5
64GMCHorsepower
Justified!
I ground mine down,then hit them with a hammer and punch when they were cool, and out they came.....
Chad
1964 GMC Fleetside Shortbed....350/700R4 tranny
64GMCHorsepower is offline   Reply With Quote
Old 01-18-2010, 01:47 AM   #6
Captainfab
60-66 Nut
I usually knock both heads off with the plasma and then blow a hole thru the center of what's left of the rivet. This can be a little tricky though so as to not ruin the hole in the frame/crossmember.
