01-18-2010, 03:41 PM | #1 |
yes, i do
front drum to disc brakes on a 72 4 door malibu
ok so i was wondering what cars/trucks originally equipped with front discs i could rob everything from the spindles outward. i found out this weekend that the mrs's 72 malibu is equipped with 4 corner drums. i've seen a couple kits on summit and e-gay, but if i can get the oe stuff from either another car/truck that either had the same or similar setup then that's what i will use. thanks guys
ERROR 404....... SNAPPY COMEBACK NOT FOUND _______________________________________________________________________________________________ -60 Chevy C10, dead 350/good th350 combo, sitting on a 76 c10 blazer frame, built from 11 different vehicles "the abomination" -07 gmt900 silverado 1500 lt xcab z71, granite blue -81 suzuki gs650g "shelah"- current project -81 kz1000m1 csr "sarge" -next project (just beautification) -07 kawasaki vulcan classic vn900 |
01-18-2010, 03:52 PM | #2 | |
Re: front drum to disc brakes on a 72 4 door malibu
1968 LWB C20 / AC / Wood Bed |
01-18-2010, 04:42 PM | #3 |
yes, i do
well i checked their conversion threads and found that i have a whole list of cars that i can use. some will be harder to find being parted out or in junkyards than others. but i can modify the stock drum spindles to make the disc hardware fit, but i think that i will just find a car and rob all the parts that i need for the conversion. thanks
01-18-2010, 07:16 PM | #4 |
Which cars will actually work?
Thanks Randy |
01-20-2010, 12:22 AM | #5 |
yes, i do
well it depends on the years but the list can be seen here randy, courtesy of crakarjax for giving me the initial link:
http://www.chevelles.com/forums/showthread.php?t=107745 all the info that you will prolly need will be in the first post. and i have seen some pretty fairly priced kits out there as well for less than $600 for a full kit. but most of the ones that i have seen come with 2" drop spindles.
