Old 01-18-2010, 03:44 PM   #1
robgrin
robgrin's Avatar
56 pickup e brake
I'm trying to figure out how to run my e brake on my 56 pickup. I have a heidts cross member and hats so I had to remove the e brake lever from the frame. And I'm running a 98 comaro rear end and want to run the factory cables.Any ideas?
robgrin is offline   Reply With Quote
Old 01-18-2010, 04:10 PM   #2
lonelywanderer
Re: 56 pickup e brake
maybe you can run a pedal style e brake like a lokar or some of the later trucks run
lonelywanderer is offline   Reply With Quote
Old 01-18-2010, 08:18 PM   #3
OrrieG
OrrieG's Avatar
Here is what I did for foot pedal on my 59. It is out of a 74 truck, I found that the bolt dimension was the same as the hood hinge bolts. 56 might be a little different but principal is the same. I don't know what the camaro has my rearend is 74 truck so everything in the back worked with stock 59 brackets. All I had to do was figure out where to relocate the pulley and connect the 74 front cable to the 59 back bracket.
OrrieG is offline   Reply With Quote
Old 01-18-2010, 09:01 PM   #4
renegade6
I did something similar to OrrieG but, used custom brake cables.
Brandon
63 Biscayne https://www.pro-touring.com/threads/90718-63-Biscayne
57 Chevy Truck (sold)http://67-72chevytrucks.com/vboard/s...d.php?t=321380
72 K20 Long bed stepside (wife's)
72 K20 Long bed 396 (flip or keep...?)
The latest build: http://67-72chevytrucks.com/vboard/s...76#post8438476
renegade6 is offline   Reply With Quote
Old 01-21-2010, 01:36 PM   #5
56 one ton
I know you said you wanted to run a cable but....... I put an automatic it
a ton and half tk years back, and when you do that you lose everything in the way emergency brake stuff. My only solution that I knew of was to install
a "roll control" All you have to do is to plumb a push button valve in your
system where ever you want (mine was on the floor next to the driver seat
and less that two feet from the master cylinder). All you do is put pressure
on your brake peddle and push the button. and it holds that pressure until
you release the button. Members here can attest to the pros and cons or
the fallacy of this suggestion. If I remember right the roll control valve cost
between $35.00 and $50.00 back then.
56 one ton is offline   Reply With Quote
Old 01-24-2010, 04:07 PM   #6
robgrin
robgrin's Avatar
Good info; thanks for the replys
Old 01-24-2010, 04:28 PM   #7
blackdiesel
blackdiesel's Avatar
a line lock? make sure to plumb it into the front brakes because..... well do i really need to explain????
'57 Chevy Pickup
'56 GMC LCF Cummins
'38 Chrysler Royal
'57 2wd change
http://67-72chevytrucks.com/vboard/s...light=speedway
blackdiesel is offline   Reply With Quote
