01-18-2010, 05:44 PM | #1 |
Couple issues with 350TBI... related?
My 87 has the 5.7 TBI motor, and has a couple issues.... first the idle fluctuates alot of the time, 500rpm-900rpm and so on, I think it's the intake gasket. However, the truck is either burning or leaking oil. I burnt a quart in 50 miles today.... this happened tihs summer, anjd I got underneath and tightened the oil filter more (probably too much) and its held oil since. I changed the filter lip too, so that's not the issue.... It isnt smoking like crazy, it doesnt leave any puddles on the ground, I just want to know what it could be.
1982 K10 SWB 1987 V20 - Sold - Doh! |
01-18-2010, 06:04 PM | #2 |
Re: Couple issues with 350TBI... related?
some sort of vacuum leak would be my first guess, so intake gaskets may very well be it.
does it run fine everywhere else? |
01-18-2010, 06:15 PM | #3 |
Yes and I drove it 2.5 hrs last week all highway and got 15mpg....
01-18-2010, 06:56 PM | #4 |
I would do obvious checks for vacuum leaks. Also, do the testing procedures for the IAC. Maybe reset the IAC as well.
87 Chevy 2wd SWB: 305/700r4 Dual Exhaust, K&N Filter, Injector Pod Spacer, TBI Spacer, Belltech Front Sway Bar, Corvette Servo, Western Chassis 4/6 and c-notch |
01-18-2010, 07:13 PM | #5 |
Garage wrench
Intake or throttle body leaking vacuum for the first one. Secondly, I would check you pcv system. Check the pcv valve, the tube from it to the throttle body, and so on.
-Adam 90 V1500 GMC Suburban 350/700R4/NP241..... 01 Saturn SL1 stock DD..... |
