Factory Strippers Rule!
![]() Join Date: Mar 2009
6-Lug Dana 60 ?'s
Does anyone know if these were put in coil spring trucks? Also, are these c-clip style or retainer bearing style? How hard to find one?
"Feast your eyes on a feast of smoke." 67 Chevy Short Fleet PLAN: LQ9, 4L60, D60 Looking for School Bus Gauges - Help me out! |
Re: 6-Lug Dana 60 ?'s
Anyone? Help please!
Hit up the guys on the 4x4 section, they will have an answer for you. I'm no expert, but I think all 60's were 8 lug.
Maybe a moderator could move this to the 67-72 truck area?
Happy to be here
![]() Join Date: Mar 2000
Here ya go...
i know that they did make 6-lug Dana 60's in a very few half tons and from what i have heard they are really rare
68 C10 LWB 2/4 drop 406/th400/3.73posi 04 Silverado SS LQ9 6.0/4L65e/4.11posi AWD |
I have one. Leaf spring type, 3.54 gears, LSD. Swapping from leaf mount to coil mount is a cut and weld job. Not very difficult, just careful setup.
I almost forgot, they are bearing retainer type.
'70 GMC C1500 LWB Power disc brakes. WooHoo! Posi 6 Lug Dana 60 Last edited by ERASER5; 01-21-2010 at 12:38 AM. |
Big Red - Now its a SWB!
I've been looking into these but can't find much info on them, do they have the big hub that sticks out like in the 8 lug version? If you could I would love to get some pics of the rear end. Thanks in advance
68 3/4 ton ![]() ![]() 41 3/4 ton ![]() 01 Tahoe LT 4WD (my daily driver)-Magnaflow Muffler, Rollin on 22's 02 Ford Mustang Convertable (Wife's Car)-Flowmaster 50, Clear corners, Intake, sittin on 18's |
Chevy Enthusiast
lol
Tony 1985 GMC K2500 restoration Project: Rust, White & Blue 1989 Chevy R3500 CC Cummins & 4X4 swap some day... 1989 Burb (D60, 14BFF, 12V, NV4500, NP205, 37" tires in progress) |
1957 was the first year for the D60 rear with leaf.
I currently have a 55 6 lug rear truck in my garage. Within something non dana 60 in it. While my 57 has one. Supposedly with the research I have done 1957 was the first year for the Dana 60s. Now with the 67-68 1/2 tons they were also 6 lug many were coil spring rear. As for the 60-66 these also had come coil rear ends in them. However I don't know much about them. I would assume thats probably the earliest you would find them. I hope that helps shed some light on it. Or at least points you in a direction to look. The 67 I have right now is leaf also so I couldn't help ya with this truck on what style the retainers are.
There are two kinds of people, those who finish what they start and so on. 70 GMC Longhorn (A.K.A Money Bucket) 57 Chev 3100 05 Chevy LLY Dmax. 67 Chevy Camaro Dad's Budget Build 55 My Longhorn Build |
mini truck racer
Had a buddy in high school that had a 70' stepper . It had a Dana 60 in it and it was coil spring . He said it was out of a camper special and it was a bolt in . It was 6 lug semi float . Truck had a strong small block with a Muncie 4 speed . He had torn up 2 12 bolts .
1949 5-window 1969 Camaro 1976 Chevy Luv yellow 1978 Chevy Luv Blue 1976 Chevy Luv Black 1979 Firebird Flooded in Harvey 1999 F350 Dually 2005 GMC Sierra 4.8 RCSB 2014 Explorer (wifes) My build :http://67-72chevytrucks.com/vboard/s...d.php?t=399148 Build #2: http://67-72chevytrucks.com/vboard/s...d.php?t=653583 Last edited by hotrod 80; 01-21-2010 at 02:41 AM. |
you can also look for a dana 61.these are used in 80's ford trucks and vans.i see alot of these in wrecking yards because even though they're 8 lug,the off road guys pass them up because they are semi-floating.i'm sure it would not be very expensive to re-drill the axle shaft to 6 lug and it should be close to the dimension spec you need.some 60's ford trucks had 5 lug dana 60 axles as well.hope this helps.
ken |
#13 |
My D60 is a semi float.( ie. No it does not have the big chunk sticking out like the 8 lug full float version.) The 6 lug D60 has axle ends identical to the D44 found on the Blazer/Jimmies.
'70 GMC C1500 LWB Power disc brakes. WooHoo! Posi 6 Lug Dana 60 |
#14 |
![]() Join Date: Aug 2005
The axle you are talking about is the Dana 60-35. It is semi-floating with 6 lug flanges. It does not use C-clips, the wheel bearings press on the shafts with a ring and there is a retainer on the end of the tube. The hub is no larger than any 10 bolt. The 60-35 is pretty rare, it was a heavy duty option on GMC 1/2 ton 4X2's up to 1969 or 1970. Not sure if it was ever 'factory' on Chevys. I think the majority of 60-35's would have been used on pickups with leaf springs, but the 1969 GMC light duty parts book does show a 60-35 housing for coil spring suspension used on Suburbans and panels. It is also interesting that the book shows the 60-35 was only available with 3.54 gears.
1967 GMC CM-2500 Camper Cruiser, 351E V-6, NP 435 4 speed, Dana 60, and factory A/C. 2012 GMC K-3500 WT regular cab, 6.0L Vortec, 6L90. |
#15 |
Looks like I will have to hit up the wrecking yard to try and find one. I think one would hold up to what I have planned for my truck. Now I wonder if there are any disc setups for these rearends...
#16 |
I think your on the right trail now. 60-70
There are two kinds of people, those who finish what they start and so on. 70 GMC Longhorn (A.K.A Money Bucket) 57 Chev 3100 05 Chevy LLY Dmax. 67 Chevy Camaro Dad's Budget Build 55 My Longhorn Build Last edited by Sinisterspeed; 01-21-2010 at 04:12 PM. |
#17 |
dazed and confused
there is a member here, texanidiot that has a truck with a dana 60 6 lug coil spring rear end. i think his truck is a 69 or 70 model.
members met: redbaron69, billsbowtie,nc67 |
#18 | |
I also looked at the big drum brake kit from ECE. Still pricey, but it would suit my load carrying needs.
#19 |
Yes there are 6 lug Dana 60 rears with coils. They came with big blocks and they are 3.54s. I have one in my 1970 GMC Sierra Grande. Love it.
#20 |
Junior Member
My 69 1/2t has a six lug Dana 60. It says nothing special on the spid but the truck was set up for towing and also had air shocks.
71 Suburban 350/700R4 Project Trixie 72 CHEVY,Highlander,SWB,396,T400 Last edited by BB72CHEVKT; 01-21-2010 at 10:02 PM. Reason: spelling |
