Old 01-18-2010, 09:48 PM   #1
72GREENC10
72GREENC10's Avatar
can anyone tell me
can anyone tell me the MAXIMUM drop i can do with out a c notch, it has leafs, its a longbed, and i am in the process of a Flip on the rear
72GREENC10 is offline   Reply With Quote
Old 01-18-2010, 09:57 PM   #2
project 67 sub
project 67 sub's Avatar
Re: can anyone tell me
probably like 6" but don't plan on hauling anything and plan on bottoming out over big bumps
project 67 sub is offline   Reply With Quote
Old 01-18-2010, 09:58 PM   #3
72GREENC10
72GREENC10's Avatar
alright, thanks
Old 01-18-2010, 10:16 PM   #4
fly-n-j
fly-n-j's Avatar
I had a 70 long bed, and I did a flip on my axle and removed a couple springs and it rode on the bump stops. It was about 7" drop. Get ready for a rough ride!
fly-n-j is offline   Reply With Quote
Old 01-18-2010, 10:48 PM   #5
72GREENC10
72GREENC10's Avatar
hha, ok, i might go for that, i want to go as low as possible
Old 01-18-2010, 11:05 PM   #6
fly-n-j
fly-n-j's Avatar
The frame rail over the axle is 4.5" tall. You can put a 2" tall notch in the frame and some shorter bump stops, this will give you some room for the axle to move up. I did this to mine before I changed suspension out to a tri 3 link. OH one more thing, the top of the dif will be getting close to the bottom of bed floor at this point!
Old 01-18-2010, 11:07 PM   #7
Normy71
Are you making your own flip kit or what are you using?
I need to do something in my leaf spring rear?
pictures please
Rolled the dice and lost!!
Check Out my 71 build
http://67-72chevytrucks.com/vboard/s...d.php?t=375158
Normy71 is offline   Reply With Quote
Old 01-19-2010, 12:10 AM   #8
fly-n-j
fly-n-j's Avatar
I made my own spring perch. Cut the old one off the top, clamped the new pair on temporary, set pinion angle and then welded them on. Piece of cake for a person of your skills! BTW nice build! when and how do you plan to shorten the longbed?
Old 01-19-2010, 12:13 PM   #9
72GREENC10
72GREENC10's Avatar
well, i went to a local fab shop and they had a set of perches that just happend to fit my leaf size, and as far as the flip goes, all you have to do is remove the rear end, cut perches off, put the axle over the leafs, and weld on new perches, this is how a flip is performed, its that simple. and as far as converting it to a short bed, its staying as a long bed, just looks good to me
Old 01-19-2010, 12:14 PM   #10
72GREENC10
72GREENC10's Avatar
i will provide pics tonight of the flip and the perches.
