High capacity oil pans
Is or has anyone used a high capacity oil pan on there truck? Which style pans clear? Do you have any pictures? I was thinking of gettin one like this. and 8 qt pan. I cant picture anything being in the way but you dont know till you try/ask!
1964 Chevy C10 a.k.a. Julie Ann H.E.I. cause its better to be pointless |
60-66 Nut
![]() ![]() Join Date: Mar 2007
Re: High capacity oil pans
With those style pans there will sometimes be interference issues with the headers. It just depends on which headers you have. On my BB Suburban I have a Moroso 8 quart pan that has a straight down sump. It does hang down a bit low, but not any lower than the headers. Of course the burb isn't lowered anymore than from the extra weight of the BB.
That particular pan looks like the front of it is lower than a stock pan. It also may be an issue when installed in our trucks......something more to look at.
Power Steering Box Adapter Plates For Sale HERE Power Brake Booster Adapter Brackets For Sale '63-'66 HERE and '67-'72 HERE and '60-'62 HERE and "60-'62 with clutch HERE Rear Disc Brake Brackets For Sale. Impala SS calipers HERE Camaro Calipers HERE D52 Calipers HERE 6 Lug HERE Hydroboost Mounting Plates HERE Last edited by Captainfab; 01-19-2010 at 01:04 AM. |
We run a 6 Quart Milodon circle track pan one the short course race truck looks stock and controls the oil real well unless you are running real loose clearances its all the oil you need Fits the 79 chassiss real nice so should fit 60-66 the same
62 GMC 910 short fleetside 454 super t10 14 bolt w/gov lock 70s c20 front discs (built in the 80s) 65 GMC 930 dualwheel 292 4spd all origonal 39k mi(my sons truck) 63 GMC 950 camperized school bus, (Gus the bus) 350 4speed 2 speed rear 64 GMC 950 "spare" bus 283? 4speed detroit locker 53 GMC 1ton dual wheel bus 78 GMC c25 short course off road race truck(son's truck) 355 th400 14 bolt (www.wheel2wheel.ca) 88 Peterbilt 379 longhood (hauls race truck) ![]() ![]() ![]() ![]() |
