Old 01-27-2003, 11:13 PM   #1
72K10
Anyone replace Pitman?
I replaced the draglink on my 72 4x4, but it seems loose where it connects to the pitman arm. Is this normal? Has anyone replaced the pitman arm and gotten tighter linkage? My NAPA guy thinks that since the pitman arm is a non-wear item, it should be OK, but it's the only place in my steering where there's play. Any other 4x4's have this and got it fixed? Thanks
RLTW
70C10
72K10
72K10 Cheyenne
72C10 Cheyenne Super
72K10 is offline   Reply With Quote
Old 01-27-2003, 11:18 PM   #2
jabarlow
just wondering if you torked the nut down to specs otherwise the hole would have to be worn from something being loose on the pitman arm to draglink connection
72 Chevy K10 Short Stepside
72 gmc K2500
jabarlow is offline   Reply With Quote
Old 01-27-2003, 11:40 PM   #3
crazy4chevs
crazy4chevs's Avatar
Yes, that is supposed to be a non wear item and should be replaced.
70 chev c10 swb fleet
72 grill, sb 400, 2/4 drop.
68 chev c10 swb fleet
Early classic 4/6 drop with 4wheel disc brakes 9"rear 67-8 buckets tilt and A/C
Classic GM Truck Club of Washington
crazy4chevs is offline   Reply With Quote
Old 01-28-2003, 12:29 AM   #4
minibike
minibike's Avatar
I put a new one on my truck...not sure about it not being a non-wear item.
69 SWB
LT1/4L60E
www.classicplace.com
minibike is offline   Reply With Quote
Old 01-28-2003, 12:15 PM   #5
1971Stepside
Almost Satisfied
1971Stepside's Avatar
I would put a new pitman arm on it. Mine was shot. You will need a puller to get the old one off.
1971 C10 Stepside. LSx 6.0 with BTR Stage IV, Speed Engineering Headers, 4L80e transmission w/3200 Circle-D Stall. 3.73. Posi. Purchased this truck when I was 17. I started the rebuild (or take apart) in 1993. I have drug it around all over the country in pieces. Finally back on the road in 2021.
"I can't complain, but sometimes I still do. Life's been good to me so far."
1971Stepside is offline   Reply With Quote
Old 01-28-2003, 01:28 PM   #6
Andy4639
Old member
Andy4639's Avatar
Cool Pitman arm
Yes replace it. It shouldn't have any play in it. I replaced mine when I replaced the idler arm also made a hugh difference.
1971 LWB Custom, 6.0LS & 4L80E, Speedhut.com GPS speedometer & gauges with A/C. 20" Boss 338's Grey wheels 4 wheel disc brakes. My Driver
Seeing the USA in a 71
Upstate SC GM Truck Club
2013,14 and 2016 Hot Rod Pour Tour
http://upstategmtrucks.com/
Get out and drive the truck this summer and have some fun!
It sucks not being able to hear!
LWB trucks rule, if you don't think so measure your SWB!
After talking to tech support at Air Lift I have found out that the kit I need is 60811. Per the measurements I gave them. Ride height of truck inside spring and inside diameter of springs.
Andy4639 is offline   Reply With Quote
Old 01-28-2003, 03:57 PM   #7
COBALT
COBALT's Avatar
Any time you buy front-end parts that have tapered studs make DAMN sure the taper and tolerance are the same, and tight respectfully. Otherwise you'll end up with excessive wear (the good news), or a broken tapered stud while you're turning a corner (the bad news).
My pitman, idler, and tie rods were loose as hell, and I replaced all of them. The drag link taper was still in good shape, so I reused it. The pitman needs to be torqued to a specification, and it's A LOT. For 3/4 ton trucks the nut had to be torqued to 190 ft-lbs if I remember correctly, but the instructions that come with a new pitman + whatever your Haynes Repair Manual says what it needs to be.
Buy Moog. You won't be sorry.
'69 3/4 ton C20 2wd-350ci/TH400
'69 3/4 ton Custom 20 2wd-350ci/4sp Manual
'99 2wd 5.7 Chevy Tahoe
Seattle, WA.
COBALT is offline   Reply With Quote
