01-19-2010, 10:42 AM | #1 |
Custom Builder
Frame Dimensions
I am going to be doing the suspension on the 1966 4WD and want to convert the frame over to the 1972 polyurethane bushing type suspension. I want to use factory spring hangers so that it looks like it was made that way.
I need the frame dimensions in the following areas to see if the 1972 spring hangers will work on the 1966 frame. I have 1 1/4 ton axles (CUCV Dana 60 and 70" wide 14 Bolt) already finished and waiting to go in. I am more concerned with the front dimensions because my 14 bolt doesnt have any spring pads or shock mounts installed yet. **Outside dimension of frame for the front spring hanger and shackle mounts
1932 Chevy Roadster Car and Pick-Up - http://67-72chevytrucks.com/vboard/s...d.php?t=465709 1966 K20 Factory 4X4 - http://67-72chevytrucks.com/vboard/s...d.php?t=455484 (Sold) 1972 K5 Blazer (Sold) - http://67-72chevytrucks.com/vboard/s...ad.php?t=87530 2007 TrailBlazer SS - http://67-72chevytrucks.com/vboard/s...34#post4706534 Last edited by LeftCoast32; 01-19-2010 at 10:59 AM. |
01-20-2010, 12:40 AM | #2 |
60-66 Nut
Re: Frame Dimensions
I would think that the '66 frame would be the same width as the '72 frame. I have a '69 frame that I could measure tomorrow. I believe it would be the same as a '72.
01-20-2010, 09:14 AM | #3 |
The front will work.Do a search for threads, this has been done.
James 63 GMC V6 4speed carryall 65 chevy swb bbw V8 auto 68 K20 327/4 speed, buddy buckets 2002 GMC CC Dually Duramax 64 GMC lwb 3/4 V6 4speed SOLD 66 GMC swb bbw buddy buckets SOLD IG duallyjams The only thing that stays the same is constant change! |
01-20-2010, 09:26 AM | #4 |
Custom Builder
The measurement from the 69 should be the same. Thanks!!
1932 Chevy Roadster Car and Pick-Up - http://67-72chevytrucks.com/vboard/s...d.php?t=465709 1966 K20 Factory 4X4 - http://67-72chevytrucks.com/vboard/s...d.php?t=455484 (Sold) 1972 K5 Blazer (Sold) - http://67-72chevytrucks.com/vboard/s...ad.php?t=87530 2007 TrailBlazer SS - http://67-72chevytrucks.com/vboard/s...34#post4706534 |
01-20-2010, 09:30 AM | #5 |
Custom Builder
I have searched and I am not changing the frame, just the spring hangers. Thanks!
01-20-2010, 05:57 PM | #6 |
"Where were you in '62?"
1960-66 Chevy/GMC Truck Frame Diagram
http://67-72chevytrucks.com/vboard/s...d.php?t=325736
PROJECT: "FULL METAL YELLOW JACKET" 1962 Chevy C-10 Stepside Shortbed Nostalgia Pro/Street Pickup Truck PROJECT: "FULL METAL YELLOW JACKET Build Thread What Are You Workin' On? - 1Bad62ChevyPickup PROJECT: "TYRANNORAMBLER REX" 1969 AMC Rambler American Nostalgia Pro/Street Youtube Channel: Father Son Projects Youtube Channel: 2TIMOTHY2FITHTEEN "North and South Carolina Folks Click Here!" (((( ~ I have Parts For Sale & Miscellaneous Stuff ~ )))) "Well being as there's no other place around the place, I reckon this must be the place, I reckon...Nyuk Nyuk Nyuk" -Curly Howard Ph.D. |
01-20-2010, 08:07 PM | #7 |
Custom Builder
Thanks for the 1966 dimensions! Now, I need some 1972 dimensions that I can read (the ones posted in FAQ I cant read).
01-20-2010, 08:30 PM | #8 |
http://67-72chevytrucks.com/vboard/s...d.php?t=380922
http://67-72chevytrucks.com/vboard/s...d.php?t=379521
01-21-2010, 12:12 AM | #9 |
60-66 Nut
The frame width on my '69 K20 frame is 28 1/4" at the front spring hangers, and 34" at the front spring shackles
01-21-2010, 12:38 AM | #10 |
Custom Builder
Thanks!!
01-21-2010, 12:39 AM | #11 | |
Custom Builder
http://67-72chevytrucks.com/vboard/s...e+width&page=2
1932 Chevy Roadster Car and Pick-Up - http://67-72chevytrucks.com/vboard/s...d.php?t=465709 1966 K20 Factory 4X4 - http://67-72chevytrucks.com/vboard/s...d.php?t=455484 (Sold) 1972 K5 Blazer (Sold) - http://67-72chevytrucks.com/vboard/s...ad.php?t=87530 2007 TrailBlazer SS - http://67-72chevytrucks.com/vboard/s...34#post4706534 Last edited by LeftCoast32; 01-21-2010 at 12:39 AM. |
01-21-2010, 12:51 AM | #12 |
Custom Builder
All this help has been great. All of the 1972 Leaf Spring Hangers will work and are within 1/8" on all of the measurements.
Now I just need a complete set of perfect hangers off a 1972 4X4 to start getting ready for the Lift Springs, Greaseable Poly Bushings, Shocks and Mount up the Axles. The axles are almost finished. I still need the Ceramic Brake Pads and all the Stainless Brake Lines. I will post up pictures as soon as I have all the Brake Calipers painted. It will have Disc Brakes front and rear with 4.56 gears and lockers at both ends. I hope to have the new steel wheels real soon. They are being custom made for the truck and will be 17X9 with 5" backspace. They will have an old school look with the new BFG KM2 35x12.50x17.
1932 Chevy Roadster Car and Pick-Up - http://67-72chevytrucks.com/vboard/s...d.php?t=465709 1966 K20 Factory 4X4 - http://67-72chevytrucks.com/vboard/s...d.php?t=455484 (Sold) 1972 K5 Blazer (Sold) - http://67-72chevytrucks.com/vboard/s...ad.php?t=87530 2007 TrailBlazer SS - http://67-72chevytrucks.com/vboard/s...34#post4706534 Last edited by LeftCoast32; 01-21-2010 at 12:54 AM. |
01-21-2010, 01:02 AM | #13 |
60-66 Nut
Have you considered going with 52" springs up front and 56's in the rear with a shackle flip?
01-21-2010, 01:13 AM | #14 |
Custom Builder
I use the truck for my business so I want to keep it looking and performing great. I dont plan to do any real rock climbing and will mostly use it for trips to the Desert with toys and up in the San Bernardino Mountains camping, hiking and mining.
