Old 01-19-2010, 10:44 AM   #1
LeftCoast32
Custom Builder
LeftCoast32's Avatar
Frame Dimensions
I am going to be doing the suspension on the 1966 4WD and want to convert the frame over to the 1972 polyurethane bushing type suspension. I want to use factory spring hangers so that it looks like it was made that way.
I need the frame dimensions in the following areas to see if the 1972 spring hangers will work on the 1966 frame. I have 1 1/4 ton axles (CUCV Dana 60 and 70" wide 14 Bolt) already finished and waiting to go in. I am more concerned with the front dimensions because my 14 bolt doesn't have any spring pads or shock mounts installed yet.
**Outside dimension of frame for the front spring hanger and shackle mounts
LeftCoast32 is offline   Reply With Quote
