Old 01-19-2010, 07:33 PM   #1
lbc710
1990 Single Cab Dually
Hello everyone im from long beach ca i bought a single cab dually no bed and no motor no trans for 250$ has lien papers i need to pay 400$ for plates and registration so 650$ not bad for what i want to do heres my plan
1. How hard is it to put in either a 5.3/6.0 with 4l60e?
2. I want to lift it, its 2wd where can i find a 3 or 6inch lift? If i go 3inch ill run 33's if i go 6inch ill run 35's
3. Thank you for all your help and knowledge
4. If truck had 454/400 what can i use to mate the 5.3/6.0 to a 700r4? what engine mounts can i use? will adaptor plates work and use the 3bolt mount?
Pic is when it had bed has no bed now
lbc710 is offline   Reply With Quote
Old 01-19-2010, 08:01 PM   #2
bwood
bwood's Avatar
Re: 1990 Single Cab Dually
As far as the Gen III swap, I'm not going to say its easy, but it is popular. There are companies out there with mounts and such. I would recommend finding a wrecked complete truck with the 6.0L and get the transmission, ECM, belt drive, intake, manifolds and harness. I would go with the 4L80E transmission instead of the 4L60E. The 60E is a good transmission for a light duty truck, but the 4L80E is what would come in a truck like yours. You will need the ECM to control the trans and engine especially if you go with the stock fuel injection. If you get a donor from 04-up (maybe 03), the throttle body will be electronic (no throttle cable) and require the gas pedal from the donor or you will need to find a 99-02 (maybe 03) throttle body that used a cable. You may or may not know that the 4.8/5.3/6.0/6.2L truck engines and the 5.7L car engine (LS1) are completely different than what is in your 93. So, theres not much that can be used from your old truck (doesn't sound like there is much left anyway). If your old truck came originally equipped with a 4L80E and you have your original ECM, you could get a 4L80E from a similar year truck, a spacer to adapt to the back of the 6.0L and you could run a carb setup and have the chip in the ECM reprogrammed to ignore the sensors that will not be used on the carb setup.
2013 Ford F150 FX4
2006 Chevy Silverado 1500
1982 Chevy C1500
2020 Ford Explorer Limited
2008 Ford Escape
bwood is offline   Reply With Quote
Old 01-19-2010, 08:08 PM   #3
bwood
bwood's Avatar
You edited while I was typing, reguardless if it came with a big block or small block, the TH350, TH400, 700R4/4L60, 4L60E and 4L80E all use the same bolt pattern to the block. You will need the correct flexplate, but they are available from most parts stores.
2013 Ford F150 FX4
1982 Chevy C1500
2008 Ford Escape
Old 01-19-2010, 10:47 PM   #4
ChevLoRay
Old Skool Club
ChevLoRay's Avatar
Street & Performance, in Mena, AR sells everything you need to put an LS-series engine into any GM truck.
Check 'em out at www.hotrodlane.cc
Member Nr. 2770
Old 01-20-2010, 08:59 AM   #5
BigBlocksRule
That dually really, really wants a 454 with a 4L80E. I can hear it crying all the way from Texas...
BigBlocksRule is offline   Reply With Quote
Old 01-20-2010, 12:42 PM   #6
ChevLoRay
Old Skool Club
ChevLoRay's Avatar
Why not go for an LS-9? How's about an Allison automatic or a 6-speed manual?
Member Nr. 2770
Old 01-20-2010, 01:58 PM   #7
lbc710
Thanks for all your help guys im 22 years old and thats what i can afford right now at the moment there are 2 5.3 engines in my area for 300$ a piece so yea but no harness or pcm. How do i go upon getting a pcm? also any ideas for a lift?
Old 01-20-2010, 03:37 PM   #8
ChevLoRay
Old Skool Club
ChevLoRay's Avatar
Did you check out that website I listed above?
Member Nr. 2770
Old 01-20-2010, 08:08 PM   #9
Colt Cobra
if it were me, I would go 454/TH400 or 4l80. Emmisions will be a B tho, to bad your in Cal. and you cant get away with a diesel swap, truck would be pretty rad with a built 6.2 in it.
Colt Cobra is offline   Reply With Quote
Old 01-21-2010, 09:03 AM   #10
BigBlocksRule
I understand that the 5.3 is all you can afford, but the swap will cost a good bit more than you're paying for the engine. Those swaps ain't cheap, I looked very hard into dropping a 6.2 into my '81 Corvette, by the time I got everything I needed it was a lot cheaper to build a strong 406 AND add a lot of bling.
Plus, that dually is a heavy pig, you need torque to move it. That's why the suggestions for a big block. You can build one that'll pass emissions, too. Cores around here are less than LS cores, too.
Old 01-23-2010, 09:41 AM   #11
fiddy9apache
fiddy9apache's Avatar
i try to make it to the car show up on the mountain every year. the S&P guys are really nice guys on a business and personal level.
fiddy9apache is offline   Reply With Quote
dually
