Old 01-19-2010, 10:16 PM   #1
Benelli
Watchin the rust grow
Benelli's Avatar
Overloaded leafs? Suspension "drag"
[IMG][/IMG]
I had the bed of my pick up and that trailer loaded down with some semi-wet ash. It was very, very heavy. I emptied the trailer and the bed of the truck and went to park the trailer, I unhook it and go home to relax. I went to school this morning to hear my buddy "What's in your truck, its squatting."
After that heavy load it's still squatting an inch or two, what is causing this and how can I go about repairing it?
It doesn't "feel" right when I'm driving, the tires seem to have plenty of air and I could not see anything wrong with them. I'll give it a bath and take some pics tomorrow.
1979 Chevy K10 (H/D Front end) - 350 w/ Holley Truck Avenger, Weinald Intake manifold, headers, bored .060 over, mild cam, Built up TH350 (TranStar Shift kit) with a part-timed NP203 t-case SOLD ($3,000)
1997 Chevy Silverado 1500 - 4.3 vortec, extended cab, 21 highway MPG, stock. "Red" SOLD ($3,000)
1987 Toyota 4wd Pick-up - work in progress, future DD SOLD ($1,850)
1998 Dodge Ram 2500 Cummins 5spd Quad cab - old 12 valve with some work done
2004 Chevy Silverado - Black, 4x4, 5.3L, stock for now
Underneath that rust is a heart of gold
Benelli is offline   Reply With Quote
Old 01-19-2010, 10:24 PM   #2
78 Chevyrado
Re: Overloaded leafs? Suspension "drag"
Sounds like a spring bent from an overload. Check the springs and make sure they arch smoothly. What do you mean by doesn't feel right? does it pull, or is it rougher, mushier than usual?
78 Chevyrado is offline   Reply With Quote
Old 01-19-2010, 10:29 PM   #3
Benelli
Benelli's Avatar
It rides a mushier I guess would be the word, I hit a bump and it feels like it actually has shocks.
A bent spring would be a simple replace job, wouldn't it?
Old 01-20-2010, 08:41 PM   #4
Benelli
Benelli's Avatar
Any other opinions?
Old 01-20-2010, 08:46 PM   #5
N2TRUX
Happy to be here
N2TRUX's Avatar
Yes, if you bent the spting it would be just a matter of replacing it. Check to see that the frame isn't bent as well.
Articles-
"Jake" the 84 to 74 crewcab
"Elwood" the77_Remix
85 GMC Sierra "Scarlett"
"Refining Sierra"
Old 01-20-2010, 09:03 PM   #6
Damien
Damien's Avatar
Check the spring packs for broken leaves too. Either way you are replacing the spring packs. Make sure you do both. Its kinda like a headlight, If one goes the other isn't far behind only this affects your handling and is a safety issue.
I can still count my vehicles on two... wait three hands.
Damien is offline   Reply With Quote
Old 01-20-2010, 09:24 PM   #7
powerdriver 1958
Kid's Mechanic
powerdriver 1958's Avatar
I am betting busted leafs,Never bent any but have replaced a bunch of broken ones
powerdriver 1958 is offline   Reply With Quote
Old 01-20-2010, 09:43 PM   #8
68Timber
I know the pieces fit
68Timber's Avatar
x2...
John
79 2wd Blazer (Bruiser)
85 M1009 Blazer (Sarge) build
74 Honda Z50 build
