Old 01-19-2010, 10:32 PM   #1
fishingjred73
fishingjred73's Avatar
Pictures of what's underneath the inner cowl panel
Here's some pictures after I took the inner cowl off my '68.
This one shows the drain for the cowl
Inside the right vent box
Why cowl panel screens may be a good idea.
James
'68 Stepside (ground up in progress)
My 68 build thread http://louisianaclassictruckclub.fre...side-t956.html
'81 SWB "Pap paw" (Driver)
The 81 build thread http://louisianaclassictruckclub.fre...-swb-t960.html
Member of
www.louisianaclassictruckclub.com
https://www.facebook.com/groups/296290610747732/
fishingjred73 is offline   Reply With Quote
Old 01-19-2010, 10:45 PM   #2
redbaron69
redbaron69's Avatar
Re: Pictures of what's underneath the inner cowl panel
im dealing with rot issues in this location myself. once i get it all cleaned up and fixed you can bet i will have some kind of screen there. the only good thing about it is, once you button it all back up you cant see much of it.
69 short fleet 350/350 "under construction"
70 short step 307/3 speed
redbaron69 is offline   Reply With Quote
Old 01-19-2010, 11:17 PM   #3
capev86
that is the only real rust issue on my 72 burb also. thinking about having a drain hole drilled in the low point when i have it repaired. lmc makes a screen that goes under the cowl panel to keep out debris. the stainless one is like 50 bucks and it is on my future purchases list.
capev86 is offline   Reply With Quote
Old 01-19-2010, 11:25 PM   #4
redbaron69
redbaron69's Avatar
heres what im dealing with
Old 01-19-2010, 11:30 PM   #5
redbaron69
redbaron69's Avatar
and more.................
Old 01-19-2010, 11:35 PM   #6
68C15
blood type; Retumbo
68C15's Avatar
sad thing is the engineers haven't got any better. let's see what the new trucks look like in 40 years.
68C15 is offline   Reply With Quote
Old 01-20-2010, 12:03 AM   #7
fishingjred73
Yep red looks like we're in the same boat.
James
Member of
Old 01-20-2010, 12:25 AM   #8
Vega_67C10
Vega_67C10's Avatar
Another reason I dont want to take mine apart yet. To me it looks to be minor, but a body guy I am not, so good luck with it.
I Saw Elvis at 1000 Feet - John Force
Vega_67C10 is offline   Reply With Quote
Old 01-20-2010, 01:18 AM   #9
Zoomin
Man of Mini-Talents
Zoomin's Avatar
Dealing with that issue too.
Zoomin is offline   Reply With Quote
Old 01-20-2010, 02:03 AM   #10
usmcchevy
Has more rust than truck...
usmcchevy's Avatar
Looks like you will put whats left of my cab to good use!
1972 Custom/10 SWB, 4.8/4l80e
Build thread
LSx Swap FAQ index
usmcchevy is offline   Reply With Quote
Old 01-20-2010, 07:12 AM   #11
jim zag
ENGINE BUILDER
jim zag's Avatar
Trucks left outside for long periods of time are all a problem. Mouse nests are like sponges and can really be trouble. My original truck has typical northern rust on the bottom and can be repaired with the usual patch panels. I was going to sell it off but I think I am going to keep it and fix it. You can repair all of it but you gotta have patience!!!!
JIM ZAG
jim zag is offline   Reply With Quote
Old 01-20-2010, 10:07 AM   #12
fishingjred73
Yep Ben your cab will live on!
James
Member of
Old 01-20-2010, 03:09 PM   #13
bigguy69
dazed and confused
bigguy69's Avatar
yep i figure i am fixin to run into the same thing. that is why i am waiting to.
members met: redbaron69, billsbowtie,nc67
bigguy69 is offline   Reply With Quote
Old 01-20-2010, 03:40 PM   #14
sdailey
The Few, The Proud
sdailey's Avatar
My cab is rusted in the same place as well. Luckily I had a donor cab that I could rob the cowl off of.
For those that maybe don't know yet, the aftermarket is now making replacement cowls.
Shannon
sdailey is offline   Reply With Quote
Old 01-20-2010, 04:17 PM   #15
lchall
I actually just got one of those inner cowls in the other day. Overall I thought it was a really good part, at least on visual inspection.
There were only a couple of things I did not like. It was not entirely one piece. The face (toward the front of the truck) of the ends of the cowl that wrap around are seperate pieces that are spot welded in. Not a big deal will just have to weld up and grind smooth. The other was a few wrinkles in these areas during the stamping process. Should be able to grind down and smooth out. Other than that looks good to me. I attached a pic below with those areas circled.
I would show a test fit pic on my cab, but have to make some additional modifications. I shaved the vents off and removed the big dent in the cowl on the passenger side where the blower is at to make like the drivers side.
It's about $200 for the part, but due to the size was around $100 for the shipping. Got mine from Southern Kentucky Classics.
1967 Chevy SWB
1972 Chevy SWB
1972 Chevy SWB K20 4x4
1991 Ford F-150
2013 Dodge Ram 1500 4x4
lchall is offline   Reply With Quote
Old 01-20-2010, 07:05 PM   #16
fishingjred73
Did it include the captured nuts for the fender and outer cowl to bolt to?
James
Member of
Old 01-20-2010, 07:17 PM   #17
POPO1984
POPO1984's Avatar
I have the passenger side cowl section for sale which i bought from a member on the board i can get a pic up for anybody who is interested
1972 SWB Medium Olive
South Houston
Instagram: Antbish84
POPO1984 is offline   Reply With Quote
Old 01-20-2010, 07:27 PM   #18
lchall
Yes, it has the nuts and reinforcement plates installed for both the fender and outer cowl.
1967 Chevy SWB
1972 Chevy SWB
1991 Ford F-150
Old 01-20-2010, 07:31 PM   #19
lchall
On the passenger side it also has the channel installed that I am guessing is a path for water around the blower assembly. It's the metal piece you show in your very first picture of the thread fishingjred73.
1967 Chevy SWB
1972 Chevy SWB
1991 Ford F-150
Old 02-10-2010, 06:40 PM   #20
Zoomin
Man of Mini-Talents
Zoomin's Avatar
Attachment 536875
Does anyone know who makes this part?
Old 02-10-2010, 08:35 PM   #21
redbaron69
redbaron69's Avatar
is this piece the "cap"or the section were the vents are located? kinda hard to tell from the pics
Old 02-10-2010, 08:52 PM   #22
Zoomin
Man of Mini-Talents
Zoomin's Avatar
That piece
would fix this...
