Old 01-19-2010, 11:30 PM   #1
texassquarebodies
Truck Nut
texassquarebodies's Avatar
1/2 to 1 ton dually ? ? ?
I really want a single cab 1987 1 ton dually, with a 350 and auto. Having a hard finding one with these options. I can find 1/2 ton 1987 trucks all day. Does anyone see any major difficulties in changing a 1/2 ton to a 1 ton? I have all the parts plus some. I plan on a 6/8 drop while I am at it.
Tony Kee
Texas Square Bodies
texassquarebodies is offline   Reply With Quote
Old 01-19-2010, 11:35 PM   #2
kelgar50
kelgar50's Avatar
Re: 1/2 to 1 ton dually ? ? ?
Find a longbed 1/2 ton put the dually rear in with the dullay bed and for the front put the 1 ton a-arms and hubs on.
The easiest would be a long bed if it is a short bed truck then you have to stretch the frame.
kelgar50 is offline   Reply With Quote
Old 01-19-2010, 11:42 PM   #3
texassquarebodies
Truck Nut
I know how to do the swap. I have been working on squares for 20 years. Got my first ticket in a square. I have never done the 1/2-1 ton conversion. Just checking if there might be a hickup or two on the way.
Tony Kee
Texas Square Bodies
Old 01-19-2010, 11:55 PM   #4
79gmcc15
Gettin It One Pice At A Time
79gmcc15's Avatar
I don't see a reason why not. As long as you don't use it as a one ton because the frame is smaller and iirc thinner.
RIP ELJAY
Work In Progress 1979 GMC C1500 Trailering Special.
Getting the truck done, one piece at a time.
“You can tell a lot about a fellow’s character by his way of eating jellybeans.”Ronald Reagan
“I don’t know the key to success but I know the key to failure is trying to please everybody.” Bill Cosby
79gmcc15 is offline   Reply With Quote
Old 01-19-2010, 11:59 PM   #5
texassquarebodies
Truck Nut
Just going to drive it. If I start with a 1/2 ton, it will already have a 700r4. Won't be doing any towing.
Tony Kee
Texas Square Bodies
Old 01-20-2010, 12:14 AM   #6
RuralRoute C-30
RuralRoute C-30's Avatar
Saw this 1-ton single cab 4x4 with the dually bed for sale recently not too far from here. Nice...but more than I can afford. Wife would not be pleased to see that added to the fleet!
1985 Chevy C-30 Hydraulic Dump Bed
2001 Saturn SC2 (go to work car)
2010 PT Cruiser (wife's car)
"Reality is just a hallucination brought on by lack of alcohol."
RuralRoute C-30 is offline   Reply With Quote
Old 01-20-2010, 01:00 AM   #7
texassquarebodies
Truck Nut
I don't have a wife anymore. I can buy what I want.
Tony Kee
Texas Square Bodies
Old 01-20-2010, 01:24 AM   #8
RuralRoute C-30
LOL!!! Been there done that too! Now I just keep the shed locked. Wondering if she will notice when I put a cowl hood on the 1-ton this spring?
The "new" guy...Mark
Old 01-20-2010, 01:56 AM   #9
blazinzuk
blazinzuk's Avatar
How far are you willing to travel for one. I have seen a couple of those in the last couple months. I think one was an 87 but the other was an 84 so no fuel injection, both 2wd
blazinzuk is offline   Reply With Quote
Old 01-20-2010, 08:51 AM   #10
ghettoluxury
ghettoluxury's Avatar
The spring pad width is different between 1/2 and 1 Ton
1949 Five Window, 1973 Step Side, 2000 Z71
ghettoluxury is offline   Reply With Quote
Old 01-20-2010, 11:58 AM   #11
CHEESE
The Cheesiest
CHEESE's Avatar
there is one being built at the shop right now for Jimmy D of JDGlassworks. Itstarted life as a 1/2 ton short bed and is being turned into a static dropped short bed dually! Here is the rendering by JDurant @ eastsidedesignlab!
CHEESE is offline   Reply With Quote
Old 01-20-2010, 12:29 PM   #12
justpball
justpball's Avatar
do it tony that will be a cool ride!
Fuzzy Dice Club Member
87 Crew SWB
Build for the crew
http://67-72chevytrucks.com/vboard/s...d.php?t=430082
http://www.cardomain.com/ride/3232925
90 burb 2wd
Build Thread For The Burb!
http://67-72chevytrucks.com/vboard/s...d.php?t=383055
justpball is offline   Reply With Quote
Old 01-20-2010, 01:36 PM   #13
71swb4x4
71swb4x4's Avatar
Tony, I believe the one ton frame is beefier than the 1/2 ton frame. It may not be an issue for you, just thought I would point it out. I am sure you already know it, but didn't want you to get into the swap and realize it then.
Some people are like slinkies, they aren't good for anything, but you can't help but smile when you see one tumble down the stairs.
71swb4x4 is offline   Reply With Quote
Old 01-20-2010, 03:15 PM   #14
texassquarebodies
Truck Nut
Hopefully I won't run into any major problems. I have about 25 or so part trucks. I will make it work. I plan on running 3/4 ton springs for a better ride.
Tony Kee
Texas Square Bodies
Old 01-21-2010, 12:07 AM   #15
DropTopZ28
my mom keeps telling me that if it wasn't for my wife i wouldn't have half the stuff i have. i tell her no, if it wasn't for my wife i would have twice the stuff that i have.
DropTopZ28 is offline   Reply With Quote
Old 01-21-2010, 12:12 AM   #16
Captkaos
www.73-87chevytrucks.com
Captkaos's Avatar
Tony,
You shouldn't run into any gotcha's, especially if you have the parts to convert. Crossmembers are virtually the same, so you can actually just put the 1T on there. Rear you will have to use the 1T mounts/springs/Axle.
Chris Lucas
1973 Chevy C-10
1978 GMC Jimmy (2WD) - SOLD
1987 R10 twin turbo LS
1991 R3500 SRW CrewCab
Captkaos Customs
Old 01-21-2010, 12:14 AM   #17
N2TRUX
Happy to be here
N2TRUX's Avatar
What about the spring hangers? Will they be to tall for the 1/2t frame?
Articles-
"Jake" the 84 to 74 crewcab
"Elwood" the77_Remix
85 GMC Sierra "Scarlett"
"Refining Sierra"
Old 01-21-2010, 12:47 AM   #18
joe231
joe231's Avatar
If your gonna flip the rear axle you could just use the 1/2 ton hangers and move the axle perches outboard
CHEVY ONLY
Old 01-21-2010, 10:15 AM   #19
texassquarebodies
Truck Nut
I know the front is a simple swap, but the rear i am unsure of.
Tony Kee
Texas Square Bodies
Old 01-21-2010, 03:07 PM   #20
Patriot
I have 2 1979 1 Ton regular cab duallys. One is a 4X4 and the other is a 2wd GMC. I need the frame off of the 2WD and will be putting all of my 4X4 stuff under the frame. I will be taking out the complete front suspension. Let me know if you need the front end.
Patriot is offline   Reply With Quote
Old 01-21-2010, 06:09 PM   #21
texassquarebodies
Truck Nut
Thanks for the offer, but I have 3 or 4 dually trucks for parts.
Tony Kee
Texas Square Bodies
Old 01-22-2010, 08:38 AM   #22
78-5.3
78-5.3's Avatar
i blew a turbo 400 in my crewcab dooley and threw in a 700r4 and did some amazing hauling with that truck best tranny i ever had!!!!!!!!!! and i saved gas
78 C-10 5.3 LSX -4L60E
78-5.3 is offline   Reply With Quote
Old 01-22-2010, 08:52 AM   #23
larrystone
larrystone's Avatar
From your messages you just want the look of the dual wheel truck w/o any towing/hauling.
My take on this would be to add a set of dually fenders with just a set of wide rear wheels and tires.
1992 C1500 WT LWB 4.3TBI 700r4 4.10 limited slip= Work Truck
1986 C10 Custom Deluxe LWB 4.3-4V TH350C 2.73 ac cruise tilt= Cowboy Cadillac
larrystone is offline   Reply With Quote
Old 01-22-2010, 07:38 PM   #24
DropTopZ28
i have been thinking of doing this also but it looks to me like the factory dually fenders will be to long for the short bed to look right. are you using the factory fenders or are ya making some shorter ones? have you got any pics of the bed with the fenders on?
Old 01-22-2010, 07:58 PM   #25
CHEESE
The Cheesiest
CHEESE's Avatar
Jimmy is using factory fenders. They are not too long. I will see if he has them mocked up yet!
