01-20-2010, 01:33 AM | #1 |
a little time...
Found a little time to bang on some sheet metal last night and tonight. About 6 hours overall. Got the passenger side kick panel, A pillar, inner rocker with 4 inches of floor, front and rear supports all mocked up. Have a few minor "adjustments" to make on the inner rocker/floor but shouldn't be too bad. I welded in the kick panel but need to get some POR15 (or similar) to paint up in the A pillar and supports before I weld them up. If I can find some time tomorrow I'm hoping to get the rest of this side welded up so I can start on the driver side. Once I get both sides done I'll upright the cab so I can hang the doors to do the B pillars, outer rockers and cab corners. Have a couple of small floor patches that need to be done then too.
Got a lot more to do yet but progress none the less. Here's a few pics for ya. |
01-20-2010, 01:36 AM | #2 |
Re: a little time...
a few more. Look how nasty my garage is. Christmas is a big affair at my house and it takes quite a while to get it all up.
01-20-2010, 01:47 AM | #3 |
SWB 4x4 Collector
Looks good Marq, but make sure you test door fit before final welding. I don't see much of a brace system, and it could throw off your door fitting nicely. Other than that, you are well on your way, good job. Trevor
TREVOR 1970 CST swb 4x4 (speedwarning,cruise,tilt,tach,8track, original red shoulder belts,tow hooks) 1972 Jimmy (soon to be Hickey cloned) 1971 Cheyenne Super 4x4 swb (tilt,tach,buckets, original blue shoulder belts,am/fm,cruise,tow hooks, dealer 8 track) 1972 Cheyenne Super K20 4x4 Custom Camper (tilt, tach, am/fm, tow hooks, bed toolbox, aux gas tank 1972 Cheyenne Super Crew Cab K30 4x4 Duramax, Allison, np205, buckets, tow hooks (CURRENT PROJECT) http://67-72chevytrucks.com/vboard/s...d.php?t=624819 1989 V3500 Crew Cab (454tbi, NV4500, np205) 1970 Chevelle SS (LS5 454,th400,8track,buckets,tach) :2004 Jeep Wrangler Rubicon (daily driver) WTB: 1968-70 Cruise Control Lever |
