Old 01-20-2010, 03:45 AM   #1
Se7en Deuce
Se7en Deuce's Avatar
need help picking a new rear end
Ive tried searching but im not coming up with answers a noob can undestand
I have a 72 c20 LWB 3/4 ton 8 lug pickup with coil springs
(hope that was enough info ^ )
truck was pretty well maintained and runs excellent, so I figured the 1st mod I wanna do is to lower it.
Found a kit for 1700, but this will change my bolt pattern in front to a 5 lug, naturally I want the rear to be the same. Im hoping to find a used 5 lug rear end locally.
My questions is: what will fit, should I look for one with Posi Traction and what gear ratio should i look for, I intend to build up motor at a later time.
sorry for the noob questions but Ive searched alot today and just didnt see any straight foward answers.
thanks for any help
Se7en Deuce is offline   Reply With Quote
Old 01-20-2010, 01:46 PM   #2
usmcchevy
Has more rust than truck...
usmcchevy's Avatar
Re: need help picking a new rear end
Sounds like it would be cheaper to find a 1/2 ton in a junk yard some place and switch out everything front and rear. 1700 is a lot of money, how big of a drop are you going for?
Posi- Yes get posi if you can
Gears depends on a few things. what do you plan on using the truck for? lots of highway use? how big of wheels do you plan on running?
1972 Custom/10 SWB, 4.8/4l80e
Build thread
LSx Swap FAQ index
usmcchevy is offline   Reply With Quote
Old 01-20-2010, 02:25 PM   #3
Sinister
Between Trucks...
Sinister's Avatar
How big a drop are you looking for?
Beat it to fit,
Paint it to match...
Sinister is offline   Reply With Quote
Old 01-20-2010, 06:11 PM   #4
Se7en Deuce
so far from what ive seen in some peoples pics
5 1/2 drop in front and 6 in the rear
static drop.
Im sure my truck was meant for hauling and pulling but I dont intend on doing anything but cruising and ocassionaly small loads in the bed.
what would it cost to do air bags?
15 inch wheels probably
not alot of highway use
Old 01-20-2010, 06:40 PM   #5
Jacfourteen
Big Red - Now its a SWB!
Jacfourteen's Avatar
what tranny you planning on running? also the overall height of the tire is more important than the wheel size, the typical height is around 27-28" tall. If you're planning on running a tranny with overdrive a 3.73 would be a good choice, if not then maybe run a 3.08. That's my opinion anyways.
68 3/4 ton (Project)-350 Small Block, .030 over, 10:1 comp, 3998993 heads, C3BX edelbrock intake, comp cams XE268, Holley 670 SA, long tube headers, dual flow 40's, E-fan, Alum rad, currently under the knife getting shortened and bagged build thread
41 3/4 ton (wife's)-flatbed, fully restored to original
01 Tahoe LT 4WD (my daily driver)-Magnaflow Muffler, Rollin on 22's
02 Ford Mustang Convertable (Wife's Car)-Flowmaster 50, Clear corners, Intake, sittin on 18's
Jacfourteen is offline   Reply With Quote
Old 01-20-2010, 07:09 PM   #6
Se7en Deuce
to be honest I havent gotten that far yet, Im focused on lowering and I thought buying a kit would be easier for me since I know very little about these trucks.
When I called about the kit the guy told me I should find a rear end with 5 lug since his kit changed my 8 to 5 lug in the front.
sound right??
anyway thats all Im tryin to accomplish right now and since I have to get a new rear end I thought Id ask yall for some help.
Thank you for the tranny input though I will consider it when I get there
Old 01-20-2010, 08:13 PM   #7
usmcchevy
usmcchevy's Avatar
Thats what I was trying to get across......my bad
Build thread
LSx Swap FAQ index
Old 01-21-2010, 03:02 AM   #8
Sinisterspeed
Sinisterspeed's Avatar
Im with them.
You could probably find one of these trucks thats all rusted out but still moves for cheap. 71-72 1/2 ton 2wd. disk brake front and 5 lug all the way around. Then you could buy the drop you want. Drop spindles for a 2-300 and blocks or lowering springs. Will have everything you need to swap it all over. Find one of those swap all the parts you want. then call the scrap guy to get some money back after your done.
There are two kinds of people, those who finish what they start and so on.
70 GMC Longhorn (A.K.A Money Bucket)
57 Chev 3100
05 Chevy LLY Dmax.
67 Chevy Camaro
Dad's Budget Build 55
My Longhorn Build
Sinisterspeed is offline   Reply With Quote
Old 01-21-2010, 03:10 AM   #9
Se7en Deuce
Originally Posted by Sinisterspeed View Post
Im with them.
ok good info
i found a couple set ups fron and rear for around 5-600 locally
1 guys has a complete good cond frame with everthing attached
I work in a shop where we could swap the body over so Im considering that route.
what u guys think???
Old 01-21-2010, 03:14 AM   #10
chopped68
you could do a static drop(4 springs / 4 shocks)for a lot less money.depending on how far you go,you might need what is called a bolt in
"c" notch for the rear.I would keep the truck 8 lug though.I'm sure there is a drop spindle for 3/4 ton trucks too.8 bullet lug nuts on a smooth 15 " rally style wheel will look cool!
chopped68 is offline   Reply With Quote
Old 01-21-2010, 04:15 PM   #11
Sinisterspeed
Here is a guy that sells what your looking for near me. Maybe you could either find someone near you doing the same thing or work something out. Not sure but at least I might help you with pricing these components.
http://portland.craigslist.org/mlt/pts/1563752324.html
350.00 for Complete Front Dropout with disk and rear to match.
57 Chev 3100
05 Chevy LLY Dmax.
67 Chevy Camaro
My Longhorn Build
