Driveline angles changes in a drop
From another thread I was directed to read the importance of minimizing U-Joint angles changes in a driveline system.
see http://www.drivetrain.com/parts_cata..._problems.html Using this info, it infers that when you drop the rearend you should also raise the transmission mount and the front pivot point of the trailing arm in a coil spring suspension to keep the u-joint angle back at 0 degrees. (for leafs they recommend shims) In my 68 shortbed, the trannie mount is 38" from the engine mount and the rear axle is 112". The front trailing is 49 1/2 in front of the rear axle centerline. Doing some quick calculations, for every inch of actual drop in the rear I should raise the trannie mount point .34 inches and raise the trailing arm front pivot by .44 inches. For a 4" drop therefore I should raise the trannie by 1.36 inches and the training arm front by 1.77 inches. Are there any frustrated engineers out there that agree?
72 Fleet (died) 78 Step (sold) 55 Step named Fred (sold) 00 F150 68 Step (named El Scorcho by PO) Build thread for the new El Scorcho http://67-72chevytrucks.com/vboard/s...d.php?t=392932 |
