Old 01-20-2010, 08:42 PM   #1
72 4x4 chevy
3.73 or 4.10 what would be the best
I have a 1972 K-10, 350, 3 on the tree, 35-12.50-15 tires, running 3.07 front and rearends. The motor is strong but it`s geared to high. I think for the tires I`m going to go with 30-10.50-15 when the others wear out. I thought maybe someone on here had the same problem and could give me some good info. Thanks.
72 4x4 chevy is offline   Reply With Quote
Old 01-20-2010, 09:11 PM   #2
nickp51chevy
Registered Chevy Owner
nickp51chevy's Avatar
Re: 3.73 or 4.10 what would be the best
What are you trying to accomplish? Do you want better gas mileage or do you want to have more power to the wheels?
Love is fleeting, but Chevy trucks are forever!!!!
1970 Chevy CST C10 long box 350/400
2008 Chevy Silverado short box 4x4
Had;
1951 Chevy short box 307/T5
1988 Chevy shot box 4x4 350/350
1971 Chevy C10 long box 4x4 350/350
1971 Chevy C20 long box 350/350
1971 Chevy C10 long box 350/350
nickp51chevy is offline   Reply With Quote
Old 01-20-2010, 09:12 PM   #3
71blksuper4x4
SWB 4x4 Collector
71blksuper4x4's Avatar
4.10
TREVOR
1970 CST swb 4x4 (speedwarning,cruise,tilt,tach,8track, original red shoulder belts,tow hooks)
1972 Jimmy (soon to be Hickey cloned)
1971 Cheyenne Super 4x4 swb (tilt,tach,buckets, original blue shoulder belts,am/fm,cruise,tow hooks, dealer 8 track)
1972 Cheyenne Super K20 4x4 Custom Camper (tilt, tach, am/fm, tow hooks, bed toolbox, aux gas tank
1972 Cheyenne Super Crew Cab K30 4x4 Duramax, Allison, np205, buckets, tow hooks (CURRENT PROJECT)
http://67-72chevytrucks.com/vboard/s...d.php?t=624819
1989 V3500 Crew Cab (454tbi, NV4500, np205)
1970 Chevelle SS (LS5 454,th400,8track,buckets,tach)
:2004 Jeep Wrangler Rubicon (daily driver)
WTB: 1968-70 Cruise Control Lever
71blksuper4x4 is offline   Reply With Quote
Old 01-20-2010, 09:53 PM   #4
hayhauler71
hayhauler71's Avatar
Originally Posted by 71blksuper4x4 View Post
4.10
x2
hayhauler71 is offline   Reply With Quote
Old 01-20-2010, 09:56 PM   #5
fjthompsoniii
I think when you switch to thirty inch tires you will like the 3.07 I'd see what its like before I went and changed diffs.
fjthompsoniii is offline   Reply With Quote
Old 01-20-2010, 11:43 PM   #6
72 4x4 chevy
I want more power at the wheels and still get decent gas mileage.
Old 01-20-2010, 11:45 PM   #7
72 4x4 chevy
Old 01-21-2010, 12:00 AM   #8
nickp51chevy
I would say if you're going to a 30" wheel the go to 3.73. That's the same set up I have on my '88 4x4 w/ a 350/350 and I get about 15mpg average. I still have decent power. I'm not gonna win any drag races, but it's enough for me.
Had;
Old 01-21-2010, 12:17 AM   #9
72 4x4 chevy
I just want to be able to pull my bike trailor that hauls 2 Harleys (about 1400 lbs) and not have to down shift when I hit a small hill.
Old 01-21-2010, 12:47 AM   #10
knsmodels
I make Models
knsmodels's Avatar
I would go with the 4:10's but I would also go with like 33" tires....in my opinion the 30" will look to small on your truck....JMHO
Click to see what I do
1972 LWB K10 350/4 sp
1968 SS Chevelle 396/tremac5spd
knsmodels is offline   Reply With Quote
Old 01-21-2010, 01:00 AM   #11
nickp51chevy
30's aren't that bad. I have the stock size tires on my '71 and they are 28.8" and they don't look bad. I did put the 30's from my '88 on my '71 4x4 to see how it would look. I thought it filled up the wheel wells nicely.
Had;
Old 01-21-2010, 01:23 AM   #12
highperf4x4
x2
highperf4x4 is offline   Reply With Quote
Old 01-21-2010, 02:33 AM   #13
71blksuper4x4
SWB 4x4 Collector
oops, I misread your message. I didn't see you were wanting to put 30" tires on it. 3:07 would be fine with 30" tires. 3:73 would be better for pulling with 30" tires, and 4:10 would almost be overkill for them. I agree that you should atleast have some 33"s so the truck doesn't look rediculous without some bigger tires under a lifted vehicle. Trevor
TREVOR
Old 01-21-2010, 05:39 PM   #14
Frankie Humphries
with 30" tires you should be fine w the 3.07s
If you're not first, your last!
Frankie Humphries is offline   Reply With Quote
Old 01-21-2010, 08:31 PM   #15
capev86
3.73 is a good compromise in a 1/2 ton truck. if it was a 3/4 ton and i was pulling loads with it, i'd want the 4.10. either rear gear with an overdrive will be waaaaay better than a 3.07 for solo highway driving.
capev86 is offline   Reply With Quote
Old 01-21-2010, 10:47 PM   #16
Jacfourteen
Big Red - Now its a SWB!
Jacfourteen's Avatar
x2
68 3/4 ton (Project)-350 Small Block, .030 over, 10:1 comp, 3998993 heads, C3BX edelbrock intake, comp cams XE268, Holley 670 SA, long tube headers, dual flow 40's, E-fan, Alum rad, currently under the knife getting shortened and bagged build thread
41 3/4 ton (wife's)-flatbed, fully restored to original
01 Tahoe LT 4WD (my daily driver)-Magnaflow Muffler, Rollin on 22's
02 Ford Mustang Convertable (Wife's Car)-Flowmaster 50, Clear corners, Intake, sittin on 18's
Jacfourteen is offline   Reply With Quote
Old 01-21-2010, 11:31 PM   #17
69 longhorn
on a 30" tire, I would agree that a 3.73 will give you the best all around power. If it were mine, I would swap the 35's for the 30's that you are lookin at, & see how she feels. You are running 3 series gears, & can swap to a 3.42 gear set without swapping carriers(a little cheaper in the long run). The 33" tires will take 3.73 to 4.10 gears to be "right with the world", & you will be 4.10-4.56 with 35" tires (to get the best power). Best of luck,crazyAL
http://community.webshots.com/user/hotrodhorn
69 longhorn is offline   Reply With Quote
Old 01-22-2010, 04:16 AM   #18
Sublvr72
Sublvr72's Avatar
If you have a 3 speed transmission 3.73's, if you have over drive 4.10 would work. If you want gas mileage stick with 3.73 regardless of what trans you have
Sublvr72 is offline   Reply With Quote
