Old 01-28-2003, 06:12 AM   #1
chevyhouse
BEER-Vacation in a can...
chevyhouse's Avatar
exhaust clearance lowered trucks
has anybody ran exhaust inside the framerails? is that even a safe/smart thing to do? i would like to go though the hanger bearing crossmember instead of under it. has anybody done this or what can be done for clearance on lowered trucks.
Kurt
03' Trailblazer
69' C10 "SPSHL-K", 388 stroker/BTO 700R4, 2400 stall, 3.73 posi, lwb, fleetside long box, 3.5"/5" drop, 18" Budnik
2000 Yamaha V-Star 1100 Custom
For Sale-87' V10-4x4, 408/700r4, 4.10's PM for pics
chevyhouse is offline   Reply With Quote
Old 01-28-2003, 09:39 AM   #2
Reumster
L.E.D. Freak
Reumster's Avatar
Many people do it. You must cut 4" holes out of the crossmember, I recommend welding in a 1 1/2" thick piece of 4" pipe. You also need shorty headers.
Specializing in Custom L.E.D. inserts.
http://www.ccled.com/
Contact me @ blazer2wd1972@hotmail.com
(406)675-8082
or Joel @ jmcwaters@eps-corp.net
1972 2wd Blazer, 350/700R4/3:73 posi, err & Custom L.E.D. inserts! LOL
Reumster is offline   Reply With Quote
Old 01-28-2003, 10:43 AM   #3
1971Stepside
Almost Satisfied
1971Stepside's Avatar
here is a pic
Here is what I did to my frame to route the exhaust. There are many of us that have done this. If you want to see it with exhaust actually routed check out Slammed67's web site. I used 4" pipe cut at 1/2" thick. We cut the frame with a sawsall and welded them in. You can also check out Early Classics Web site as they did this mod to Dave's 68.
1971 C10 Stepside. LSx 6.0 with BTR Stage IV, Speed Engineering Headers, 4L80e transmission w/3200 Circle-D Stall. 3.73. Posi. Purchased this truck when I was 17. I started the rebuild (or take apart) in 1993. I have drug it around all over the country in pieces. Finally back on the road in 2021.
"I can't complain, but sometimes I still do. Life's been good to me so far."
1971Stepside is offline   Reply With Quote
Old 01-28-2003, 10:46 AM   #4
1971Stepside
Almost Satisfied
a second
angle
Old 01-28-2003, 11:37 AM   #5
ChevLoRay
Old Skool Club
ChevLoRay's Avatar
....71stepside.....
Boy, your shop looks nice! If having a painted floor makes it easier to work on your truck, I should put that task on my list of things to do, BEFORE I start on my truck (which I have now parked to begin the off-the-frame restification.
Member Nr. 2770
Old 01-28-2003, 11:48 AM   #6
HotRod929
HotRod929's Avatar
Location: Bondurant, IA but in Worcester, MA for school
How low can you go with long tube headers and it exiting out behind the rear wheels? I was thinking a 3/6 or 3/5 drop for my 70 C20...will I have problems with that?
HotRod
1970 Chevy C-20
350 V-8
Turbo 350 w/ shift kit
Dana 60 w/ 4.10 gears AND Powr-Loc POSI
New Additions:
Summit Headers
135amp alternator
Proform HEI
Edelbrock 1406 600cfm carb
Sunpro Tach
Powr-Loc POSI
Edelbrock Performer RPM Intake
MSD 6A Ignition Box
AIM: HotRod929
Visit My Site: http://1970chevy.netfirms.com/
HotRod929 is offline   Reply With Quote
Old 01-28-2003, 12:02 PM   #7
1971Stepside
Almost Satisfied
ChevLoRay, I wish I had a shop but that is just my two car garage that my wife also wedges her mini van into every night! I painted the floor and the stuff is great to clean up oil or other spills. Make sure you get the oil based stuff as the water based stuff sucks.
HotRod, you should have no trouble with a 3/6 or 3/5 drop. You probably wouldn't want to do this, but there is very minimal cost in doing it.
Old 01-28-2003, 02:32 PM   #8
Castiron9
72 LONGHORN OWNER
Castiron9's Avatar
Oh man That looks nice and very organized..............Some day.............
Castiron9 is offline   Reply With Quote
Old 01-28-2003, 03:44 PM   #9
GloryHound
Working on a Nova.
GloryHound's Avatar
Has any buddy tried stacks inorder to eliminate the clearance problems with the rear axle? I'm looking into this I'm just not sure how it will look on a fleet side! Another Idea I'm considering is putting a second floor in at wheel well height and using the area inbetween for running pipes and wiring if need be!
GloryHound is offline   Reply With Quote
Old 01-28-2003, 05:15 PM   #10
XXL
Seņor Member
XXL's Avatar
Well, I'm picturing something like this, only with a truck...
Kenneth
XXL is offline   Reply With Quote
Old 01-28-2003, 05:33 PM   #11
crazy longhorn
Fabricate till you "puke"
Wow thats cool XXL I think a set of stacks would look good on a flatbed, or even on a stepside.....but I think they would look out of place on a fleetside truck....crazyL
69 longhorn,4" chop,3/5 drop, 1/2 ton suspension/disc brakes,1 1/2" body drop,steel tilt clip, 5.3/Edelbrock rpm intake/600 carb, Hooker streetrod shorties,2 1/2" exhaust/ H pipe/50's Flows , 6 spd Richmond trans,12 bolt/ 3.40 gears....
crazy longhorn is offline   Reply With Quote
Old 01-28-2003, 06:22 PM   #12
HotRod929
HotRod929's Avatar
I wonder how those stacks would look as side pipes on a fleetside? Kinda like the way corvetts had em you know...under the door.
HotRod
1970 Chevy C-20
350 V-8
New Additions:
Summit Headers
135amp alternator
Proform HEI
Sunpro Tach
Powr-Loc POSI
MSD 6A Ignition Box
AIM: HotRod929
