Badass
front tires stick out diffrent
the front tires on my truck stick out diffrent,my driviers side is more out then my pass by a little more then a inch?
Think outside the box? -84c10 (1stcar)→My Build← ![]() -00 Saturn 5spd drop a gear and disappear! 1/4:13:90 ![]() |
6.0 powered square
Re: front tires stick out diffrent
mine also do it
Aaron 1980 c-10 short bed lowered, cammed 6.0, 4l80e 3600 stall, smp tune, wilwoods, and flames best time so far best et 7.86 @87 on motor 7.57 90 on a 75 shot Build http://67-72chevytrucks.com/vboard/s...d.php?t=283326 |
Badass
i can tell now more after i lowerd it and only my drivers side rubs the outer fender lip
Formerly- 1972SuperCheyenne
![]() Join Date: Oct 2008
If your drivers or passenger side tire sticks out an inch more than the other, you have a major issue. Hope the frame's not bent.
--Josh My Build Thread:http://67-72chevytrucks.com/vboard/s...d.php?t=799218 A good crossthread is better than Loctite any day. Life is not about what you have, but who you have to share it with. |
Badass
well its just about a inch. its enough that i could tell it wasnt the same on both sides.do it come stock like that???idk
Have you had an alignment done?
Sure the "tires" are what is out of center and not your "body" ? i.e. driver's fender vs passenger fender distance to frame center is off . . . . ?
-Josh "Mr. Simpson, there are thousands of people like you with no discernible talent." Duff World Records Division "Yeah, they're called Congress!!" -Homer Simpson |
It followed me home?
I've owned over 10 square bodies and all of the 2wd's have had that same issue, not quite an inch but definitly noticeable.
Adam That's why they call it a shortcut Kyle, if it was easy it would just be the way. 86 c-10 SWB 85 CCSB 90 GMC K30 Crew SRW 1985 C30 Dually Last edited by cochino12; 01-21-2010 at 01:09 AM. |
This black truck in my avatar is my 9th square body. Yes, the front tires stick out more than the rear but none of them have ever had an issue with the drivers or passenger side sticking out an inch more than the other. Something is either wrong with the body mounting or there is an issue with the suspension. May just bee more positive canber on one side than the other, hopefully nothing is bent. Grab a tape measure and crawl under there and let us know what you find.
Robert Olson Transport
![]() Join Date: Oct 2002
id look into it too... maybe ask a front end shop.There is a thread on here where the OP has risted control arms... maybe the control arms is damaged or the bushing is bad?? Ive had four or five of these trucks and if one tire stuck out noticibly more id notice it, Of course the lowering would make this more obvious and i prefer my trucks higher
Make sure the cab is set square on the frame.
One of the problems with these trucks (when new) is that the cab is so short that when it was set on the frame at body drop it could be rotated to one side or the other. The hood is set to the cab, shooting straight forward off the cab but off to one side compared to the frame. Then the front end (fenders and rad support) are "squared" to the hood, equalizing the gap between the hood and fenders but causing them to shoot off to the side, too. One way to check this is to look at the gap between the front bumper and the fenders on each side. The bumper is attached to the frame and therefore centered; any difference side to side could indicate the problem above. This was not so much of a problem with the crew cabs, Blazers or Suburbans, because the longer body made it more robust against being set on there crooked. K
Chevrolet Flint Assembly 1979-1986 GM Full Size Truck Engineering 1986 - 2019 Intro from an Old Assembly Guy: http://67-72chevytrucks.com/vboard/s...d.php?t=342926 My Pontiac story: http://forums.maxperformanceinc.com/...d.php?t=560524 Chevelle intro: http://www.superchevy.com/features/s...hevy-chevelle/ Last edited by Keith Seymore; 01-21-2010 at 10:05 AM. |
1962 C-10
My '73 has the same issue, but my truck was in a front end collision before it was parked, years ago, years before I bought it. The body mounts took shape and dried out to this position. I noticed the body alignment issues when I replaced the fenders and hood. Right now they are adjusted to look 'square'. I haven't yet replaced them, but to me it looks like new mounts would be the fix for my situation.
Also, very good info Keith! Interesting...
Joseph Chavez ![]() "See the USA in a Chevrolet!!" ......................_____ .........________//__{\_____ ,,,,,,,/__(O)___//___/__(O)_/ 1962 C10 Shortbed Fleetside 327/th350 GV overdrive 1974 C10 Longbed Fleetside 350/th350 "The Trash Truck" 1999 Chevy 2500 OBS, Longbed 5.7/4L80E 4x4 2015 GMC Sierra SLE 1500 4x4 |
#13 |
very good info! thanks Keith... something to keep in mind when the cab goes back on.
"Dennis the Menace" 1978 Silverado (2wd, 1/2 ton, short bed)complete nut & bolt frame off restomod LQ9/4L80E MY LS SWAP/FRAME OFF BUILD BOOK 2006 TBSS way too much to list ![]() |
#14 |
Next project: 1970 K10
Yep, keep everything snug, instead of fully tightening everything down, until everything has been straightened and aligned. Then nail it all down.
Bob 1970 Chevy K10 LWB "Goldie" 350/TH350 next project!! 1981 Chevy C10 LWB 355/TH350 - My son's truck LS SWAP FORUM! Tons of LS swap info here! PLEASE CLICK HERE TO SUPPORT THE GREATEST BOARD ON THE NET! CLICK HERE FOR THE FAQ INDEX by KRUE |
#15 | |
#17 |
You may need to check you camber. You may have too many shims on one side if the top of the tire is out farther than the bottom. My 83 is bagged and when dropped they hit the fender but the same on each side, I just remove the inner lip so they don't rub anymore.
#18 |
haha, ford guys...
agreed^^^
also, chevy put a stiffer spring on the air compressor side... do u have an ac truck? ac removed? thus leaning and throwing u off? |
