Old 01-21-2010, 01:28 AM   #1
70 Suburban
Rods
new rear fo 66?
how about an 08 chevy disc rear in the 66? any one tried. looks to wide
Just keepin it simple.
1965 C-10 Ext cab build. 350??(Does it count at 2 truck if I had to cut one up?)
1966 C-10 lwb 283 auto
1970 Suburban in pieces
1971 Blazer 4wd....restore someday. all factory CST
1972 Blazer 4wd parts truck still a roller
1972 GMC Sierra Grandee
1998 Chevy ext driver.
2005 F**D the wife drive...(cant fix women)
70 Suburban is offline   Reply With Quote
Old 01-21-2010, 08:49 AM   #2
70 Suburban
Rods
Re: new rear fo 66?
bump
Old 01-21-2010, 10:56 AM   #3
protrash64
Resistance is Futile
protrash64's Avatar
Re: new rear fo 66?
I have seen a sb fleetside with the earlier 6-lug disc rearend. It will fit with the correct back space on ones wheels, of course. They are wider, but I'm not familiar with the new drum set-ups.
64 CHEVY PICK-UP > http://67-72chevytrucks.com/vboard/s...otrash+re-hash
64 CARRYALL >http://67-72chevytrucks.com/vboard/s...=1964+suburban
66 LB >http://67-72chevytrucks.com/vboard/s...d.php?t=427852
STRENGTH/DETERMINATION/MERCILESS/FOREVER
.......posted via stationary device
protrash64 is offline   Reply With Quote
Old 01-21-2010, 11:09 AM   #4
70 Suburban
Rods
Re: new rear fo 66?
I have the later disk rear. I want to use if but im not sure what it will do as far as the front(looks) thanks for the info.
Old 01-21-2010, 11:16 AM   #5
protrash64
protrash64's Avatar
Re: new rear fo 66?
I think you may have to run some wheels with deeper offset...5''+. They work great with the front disc conversion and should sit nicely in the rear. I wanted this coversion for awhile but my old '68 rearend has brand new brakes and I'd like to use them some.
Old 01-21-2010, 11:45 AM   #6
70 Suburban
Rods
Re: new rear fo 66?
Lol mine does too, but i have the rear and its sitting there with less than 3800 miles on it. I have the stock wheels from the sub also... I think that will look nice on my truck
Old 01-21-2010, 11:51 AM   #7
protrash64
protrash64's Avatar
Re: new rear fo 66?
I agree. The only thing weird would be the metric studs...I figured I'd press them out and go SAE to match the front. And to be clear, the truck I saw was a few years ago and it was running a '99-'02 rear. I dont know if they've changed at all since that time period. Cheap way to go for 4 wheel disc.
Old 01-21-2010, 12:25 PM   #8
70 Suburban
Rods
Re: new rear fo 66?
I already have metric in front when i did my 6 lug disc from the 2000. So it will match for me
