Old 01-21-2010, 08:26 AM   #1
Larry S
Larry S's Avatar
05 2500 hd tranny fluid change
I have an 05 2500 Hd 6.0 vortec auto. The truck only has 42,000 miles. I pull a 30 ft camper with a trailer hooked to it w atvs thru the n ga mtns alot thru the summer. Its some hard pulls, so I was thinking about changing the tranny fluid. I was planning to do it myself, but I'm kinda busy so I called "stealership" and got a quote. They said around $225. My question is WHY IS IT SO EXPENSIVE? I usually work on my own stuff and am wondering, if it cost that much, is there "something Im missing."
Larry S is offline   Reply With Quote
Old 01-21-2010, 01:27 PM   #2
463
463's Avatar
Re: 05 2500 hd tranny fluid change
look close to what i am thinking. 35 for the filter kit 50 for fluid, 100 for the hour and tax,shop mat ect. i look at the shop rate and go from there.
463 is offline   Reply With Quote
Old 01-21-2010, 07:01 PM   #3
Larry S
Larry S's Avatar
Ok. Thanks. I just want to be sure there isnt some special procedure that Im not equiped to do. Like the stupid oldsmobile mastercylinder I was dealin with last month.
Old 01-21-2010, 10:03 PM   #4
ed2552
ed2552's Avatar
No, it's a basic pan-drop and filter change. Check and see what a local shop (independent, non-dealer) will do it for. Probably be cheaper than the dealer. Also a good time to upgrade to a high quality fluid like Amsoil, since you're doing some hard pulls.
'67 C20, Under the Knife!, LWB, Eaton HO-52, Rear Coil Springs
72' GMC C2500, 350, TH400(?), Dana 60
'67 K10 4-spd., 305, SM465, Dana 44, 12 Bolt, RUST!
'65 C60 292, 4 spd, 2 spd Rearend, 15' Grain Box, MINT!
09 Yukon Denali 82k Miles 6.2L/6A
ed2552 is offline   Reply With Quote
Old 01-22-2010, 06:40 AM   #5
Larry S
Larry S's Avatar
ok thanks guys.
