01-21-2010, 08:29 AM | #1 |
Headers
Okay, I was wondering what the best headers are for the price. I have some Headman long tube on my truck now and I am not happy with them. I can't keep gaskets on them. I have been looking at Doug Thorley and Sandersons but they are pricy. Are there any others out there that campare to those?
Thanks for your input. |
01-21-2010, 08:45 AM | #2 |
Re: Headers
I'm shopping for headers too, although my budget is pretty small. I'm leaning toward the Hooker #2452.
01-21-2010, 09:10 AM | #3 |
Formerly- 1972SuperCheyenne
Re: Headers
Which gaskets are leaking? I always use regular old exhaust manifold gaskets at the head (yes, with headers) and it never leaks. Works perfect. If they are not the ball and socket fit at the collectors, use 3 inch donut gaskets for exhaust manifolds there. They fit in place of the paper gaskets and also never leak. I have done this for years and have NEVER had an exhaust leak. Good luck.
--Josh My Build Thread:http://67-72chevytrucks.com/vboard/s...d.php?t=799218 A good crossthread is better than Loctite any day. Life is not about what you have, but who you have to share it with. |
01-21-2010, 10:38 AM | #4 |
Re: Headers
I have tried several different kind. They are Hedman headers and the flange that mounts to the head are thin. I am looking for some with a thicker flange, some are even machined to fit each exhaust port.
The hooker ones mentioned above use 16 gauge pipe and 5/16" flanges and are about $350.00 from what I found. |
01-21-2010, 11:40 AM | #5 |
Re: Headers
I have hooker competition header on my blazer with a cardboard type gasket that is about 3/16" thick. The only time they leak is when the bolts loosen up, which when I was driving it daily was about every six months. I would just tighten the bolts and they were fine. I've never replaced them. I got them from a local race shop. I think I paid about $200 with my employee discount which normally was about what summit charged for stuff. They came ceramic coated too. I'm not sure if they were supposed to be or if someone shipped the wrong ones. I know I didn't specifically order them that way.
I can still count my vehicles on two... wait three hands. |
01-21-2010, 01:50 PM | #6 |
Re: Headers
I never fool with exhaust gaskets and just use some red silicone. Never have any leaks with it.
01-21-2010, 02:18 PM | #7 |
Re: Headers
They all suck. Went back to stock manifolds and have better power, as they add some restriction the true duals don't allow for. Stock air cleaner also. That way I'm not dumping/wasting more gas for a couple of horsepower. Good power AND 14 mpg!
-Josh "Mr. Simpson, there are thousands of people like you with no discernible talent." Duff World Records Division "Yeah, they're called Congress!!" -Homer Simpson Last edited by ToughBowtieTruck; 01-21-2010 at 02:19 PM. |
01-21-2010, 02:26 PM | #8 |
Re: Headers
Well the exhaust is already setup for the long tube headers and don't want to have to go to the muffler shop.
What brands and models are the ones ya'll are having good luck with. Do you think the thickness of the flange has anything to do with it? |
01-21-2010, 02:48 PM | #9 |
Re: Headers
I just put the copperseal gaskets by Mr Gasket on my headers. My cousin has them on his Camaro, and said it's the best gasket he has used. So I'm giving them a shot on mine.
01-21-2010, 03:03 PM | #10 | |
1962 C-10
Re: Headers
Joseph Chavez "See the USA in a Chevrolet!!" ......................_____ .........________//__{\_____ ,,,,,,,/__(O)___//___/__(O)_/ 1962 C10 Shortbed Fleetside 327/th350 GV overdrive 1974 C10 Longbed Fleetside 350/th350 "The Trash Truck" 1999 Chevy 2500 OBS, Longbed 5.7/4L80E 4x4 2015 GMC Sierra SLE 1500 4x4 |
01-21-2010, 03:53 PM | #11 |
Re: Headers
01-22-2010, 03:47 AM | #12 |
At the body shop.
Re: Headers
I have the dougs D-310c on a sbc. 3/8 flange top and bottom. Fit well and 0 leaks
" That didnt make it any newer " " Dont antique the equipment " |
01-22-2010, 09:28 AM | #13 |
Re: Headers
As were mine. a 90 pipe and 45, coupled to stock pipe off the manifold and they were connected. It's not difficult by any means.
-Josh "Mr. Simpson, there are thousands of people like you with no discernible talent." Duff World Records Division "Yeah, they're called Congress!!" -Homer Simpson |
01-22-2010, 10:02 AM | #14 |
Re: Headers
i just got some heddman, ceramic coated full lengths, they've got 1-3/4 primaries, 3 inch collectors, ill let you guys know how they are when it gets on the road.
01-22-2010, 10:23 AM | #15 |
Still plays with trucks
Re: Headers
I have used the Pacesetter headers on several cars and really like them. I have the ceramic coated ones on my Malibu.
USA made, 3/8" thick flanges and you can get them ceramic coated if you want. http://www.jegs.com/i/Pace%20Setter/...0002/-1?CT=999 http://www.pacesetterexhaust.com/quiktrip.php They make shorty versions that hook up to the stock Y-pipe on the 88-95 trucks that should fit our trucks too if you need to run a single cat.
miSSed opportunity - ground up creation of an AWD 1994 454 SS that never was http://67-72chevytrucks.com/vboard/s...d.php?t=795577 69 C10 shortbed stepside 400 small block - built like what a super sport truck could have been 69 K20 lwb TBI 350 4L60E NP208 14-bolt Dana-44 w/disc 68 Camaro SS / RS 500hp 439 inch roller cam big block 4L80E 79 Malibu TPI 350 4L60 w/ Z28 steering & sway bars |
01-22-2010, 10:27 AM | #16 |
Squarebody Aficionado
Re: Headers
before you go out and buy new headers add an extra set of gaskets. we usually just put 2 sets of gaskets in and we never have a problem. BTW we own an exhaust shop here in Miami, but then again its only my 2 pennies. I still havent ran into a set of heads/headers that match up perfectly.
01-22-2010, 10:59 AM | #17 |
Re: Headers
Already tried the two gasket thing. I have my truck in the shop now and I was going to get them to put gaskets on them. They called and told me the headers were warped and can't get a good seal.
Those Pacesetter ones looked pretty good. Machined 3/8" flanges. I think I'll give them a shot. I don't get the "Off Road Use Only" at the end of the description? 72C2265 PaceSetter now offers quality-made, affordably-priced long tube headers for full-size light duty pick up trucks and SUVs. CNC-machined 3/8"-thick steel flanges are matched to exhaust port profile for optimum seal and flow. Flash-controlled 16-gauge carbon steel primaries provide greater durability than light gauge stainless steel. Length and diameter of mandrel-bent tubing is optimized for flow and best performance increase. Tubes enter collector in proper sequence for maximum scavenging. O2 sensor fittings on all applications. Complete with necessary gaskets and fasteners for installation. Made in USA Affordably priced Off road use only. Last edited by mhicks; 01-22-2010 at 11:00 AM. |
01-22-2010, 09:04 PM | #18 |
Re: Headers
"Off Road Only" just means they are not emissions compliant. If you don't have inspections you won't have a problem.
01-22-2010, 11:48 PM | #19 |
GM Addicted
Re: Headers
i want to put a set of headers on my truck, ones that will fit the existing pipe so i can still run my cat, any out there thatll work
..Mac’s Garage.. 73 GMC, 54 Caddy, 2010 Silverado, 68 C10 RIP DAd My 73 GMC Truck Build Pic 2010 Silverado 4/6 on 24s IG:MacsGarage |
01-23-2010, 02:23 AM | #20 |
78 Big10 454
Re: Headers
I installed a set of CARB-compliant Hedman Headers in 1979. Used the Hedman gaskets that were supplied with the headers. Almost 31 years later and nary a leak. Maybe quality was better three decades ago?
01-23-2010, 02:48 AM | #21 |
Re: Headers
01-23-2010, 11:35 AM | #22 |
Re: Headers
Pacesetter doesn't list a shorty header for our trucks but does have them for the 88-95 which has the same engine so they might work. Can't be that much difference in them. Minor mods to the Y-pipe if any.
01-23-2010, 01:01 PM | #23 |
Re: Headers
I currently have dual exhaust that goes straight out the back. What is the a Y-pipe and what would need to be done to use that style?
01-23-2010, 01:25 PM | #24 | |
Re: Headers
01-23-2010, 01:28 PM | #25 |
Re: Headers
i have hedman longtubes on my truck, they have been on there for over 2 years with stock manifold gaskets and i have never had a problem before.
2006 GMC Sierra CCSB, 6.0 swap 2000 Chevy C3500 Crew Cab shortbed dually 1999 Chevy c2500 Crew Cab shortbed 1982 El Camino 350/350 1979 K5 2wd blazer bagged/bodied 1986 Monte Carlo SS 1991 Chevy CK SWB-67 clip and tailgate, bagged 350/700r4 1955 Chevy Bel Air 2014 Chevy Silverado ccsb |
