Old 01-21-2010, 01:37 PM   #1
JohnSerbian
JohnSerbian's Avatar
How to De-Clogg a cooling system of Doom?
Hi, so’s I have a 1983 GMC Sierra Classic 2500 that’s been sitting for over a year that I’m in the process of getting started. There’s a whole list of fun things that I gotta take care of first, but here’s what I’m working on now.
How does one de-clog a cooling system on a non-running engine? Flush the piss outta it with a flushing compound, cold, with a hose and maybe Lime-A-Way? Make my own Hot Tank solution out of caustic soda and dunk & boil the radiator for a day? The ‘Ol battery charger hooked up to a metal rod in a plastic container full of water and the radiator Shtick? Any thoughts? Mostly I just don’t want to pay a dime for any thing when doing it yourself is so much more of the way things should be done. Sometimes. That and I’m broke! Yes? No?
P.s.; I'll post picture's soon, Think: ''Brown Barnicals" & "Thermostat Clog"
1983 GMC SIERRA CLASSIC 2500 V8 350
"When the going gets weird, The Weird turn Pro."-HST
JohnSerbian is offline   Reply With Quote
Old 01-21-2010, 02:04 PM   #2
79gmcc15
Gettin It One Pice At A Time
79gmcc15's Avatar
Re: How to De-Clogg a cooling system of Doom?
I don't know but I love the title and welcome!
RIP ELJAY
Work In Progress 1979 GMC C1500 Trailering Special.
Getting the truck done, one piece at a time.
“You can tell a lot about a fellow’s character by his way of eating jellybeans.”Ronald Reagan
“I don’t know the key to success but I know the key to failure is trying to please everybody.” Bill Cosby
79gmcc15 is offline   Reply With Quote
Old 01-21-2010, 02:52 PM   #3
old Rusty C10
Robert Olson Transport
old Rusty C10's Avatar
well i had bought my SIL a 95 blazer that was like that and we wound up changing the radiator and the guy at the shop was doing a cold flush with some kind of store bought flush and its been ok since although we did reflush after a couple of months... if its that bad you can couont on either the radiator or the core or both needing replacements
Bob
1951 International running on a squarebody chassis
"If a man's worth is judged by the people he associates himself with, then i am the richest man in the world knowing some of the fine people of this board"
http://67-72chevytrucks.com/vboard/a...t.php?f=25&a=9 (you can review the site rules here!)
PM Me for your vehicle/parts hauling needs in the North East US or see my Facebook page Robert Olson Transport
Live each day to the fullest.. you never know when fate is going to pull the rug out from under you...
I hate cancer!!
old Rusty C10 is offline   Reply With Quote
Old 01-21-2010, 03:09 PM   #4
dan76
Stay with flushing with a hose until you get a clear stream from the rad outlet. I'd put emphasis on getting the engine running and then check for a sound radiator and heater core. This way you'll save unnecessary time and effort on a worthless system. If you think the block is badly clogged, pull the H20 pump and T-stadt and flush with water. Once you get the engine running, fill with water and run it for a few miles and flush. Do this a couple of times and ensure no leaks prior to filling with coolant.
dan76 is offline   Reply With Quote
Old 01-21-2010, 09:40 PM   #5
JohnSerbian
Awesome. Thanks for the advice Dan, that sounds like what I was really thinking. I took out the water pump today and did just a flush on everything with the hose till it ran clear. Since everything was off I cleaned all the gunk off the front, and now I can't stop cleaning! But yes, plenty to worry about before I go ape-**** on the little things. Next is a tango with a shim and a starter. And Thank You, '79, good to be here! You guys have a great Site, I learn something new every day. -John
Old 01-21-2010, 11:36 PM   #6
dan76
While you're at it, might want to check condition of the block freeze plugs. If you find excessive corrosion while flushing the block, the freeze plugs might be prone to failure. Good luck.
Old 01-22-2010, 04:28 AM   #7
JohnSerbian
Hmm. See, I learn something new every day! Thanks Dan!
Old 01-22-2010, 03:41 PM   #8
78 Chevyrado
I don't know what it would to to gaskets and rubber... but you may be able to use CLR. Calcium-Lime-Rust remover. Works great! I'm just not sure if it will harm the gaskets, etc. It won't hurt the metals though.
78 Chevyrado is offline   Reply With Quote
Old 01-22-2010, 04:51 PM   #9
Malo83
Cruzzzn' Vet
Malo83's Avatar
After you flush it all out run 2 bottles of Prestone HD radiator flush/cleaner for about a week to get in and clean while you drive around and then give it another good flush. This worked for me and the inside of the Rad looked new after the flush
Malo83 is offline   Reply With Quote
Old 01-22-2010, 11:25 PM   #10
JohnSerbian
That is a good idea Malo, I'll give that a shot after I start her up. I might pour some Lime-Away in the block just for fun before I put back on the water pump, which I think is the same stuff as CLR. I'll definitly do the flush trick before I attempt to jury-rigg my own back yard Rad cooker! Although I'll try and resist. Thanks Guys!
Old 01-23-2010, 04:16 AM   #11
MylilBowTie
Right turn Clyde
MylilBowTie's Avatar
1974 C25 LWB: 454 4bbl Carb / TH400 / 3.73
1992 Camaro RS 305 TBI
MylilBowTie is offline   Reply With Quote
Old 01-04-2011, 04:27 PM   #12
kikkegek
kikkegek's Avatar
pictures?
kikkegek is offline   Reply With Quote
Old 01-05-2011, 01:54 AM   #13
454HO
Get some RMI-25. Best cooling system de-gunker there is.
opps, didn't realize this thread was a year old already.
- Greg
454HO is offline   Reply With Quote
Old 01-05-2011, 02:28 PM   #14
kikkegek
kikkegek's Avatar
WOW!
that seems like wonderstuff!
I'll see if I can find this here in the Netherlands!?!
Old 01-06-2011, 12:29 PM   #15
motornut
78K & 79C Jimmys
motornut's Avatar
started to read this thread kikkegek and was thinking of yours
glad you found it
John
1978 GMCJimmy4X4-350/203
1979 GMCJimmy4X2-305/350
motornut is offline   Reply With Quote
