shock mounts
I am having some trouble with Belltech. I bought a drop kit including shocks. The canitlever shock mount is to small 1/2" The holes in the frame are 5/8" do you guys know where I can find some shock mounts. I called my dealer and they can't get them. Belltech says they do not carry them. need some help. The front are pressed and I broke one of the rear so I only have one mount that could be used. I would like new. need some help
thanks Chris |
Re: shock mounts
try *****************
Fuzzy Dice Club Member 87 Crew SWB Build for the crew http://67-72chevytrucks.com/vboard/s...d.php?t=430082 http://www.cardomain.com/ride/3232925 90 burb 2wd Build Thread For The Burb! http://67-72chevytrucks.com/vboard/s...d.php?t=383055 |
Re: shock mounts
I called monroe tonight and they have some, but I will also try suicide thanks
Chris |
Re: shock mounts
I just went in the classifieds and got some off of a truck being parted out... both of mine broke using a little 3/8's ratchet
Re: shock mounts
The problem is about using the old ones, the fronts are pressed in the shock and I broke one of the rears. As for getting them off another trucks I guess mine is a little different because it was built in Canada, that is why I have the 5/8" hole. thanks for the tips
Chris |
Re: shock mounts
Call belltech. If their stuff doesn't work, they need to fix it or give you at least some money back.
Only way I've been able to obtain the shock mounts (special bolt through the frame) was with a new set of shocks. I hunted and hunted around and couldn't find any and went to buy the shocks and GOOD they came with the shocks. Last edited by 78 Chevyrado; 01-22-2010 at 12:59 AM. |
It'd be alot cooler if you did
Re: shock mounts
just go down to the parts store and have them rob a set out of a new pair of shocks.
At the body shop.
Re: shock mounts
Ive heard them refered to P-19 pin. Or get one of these, 4 wheel drive with dual shocks. the second shock bracket is kind of neat too
" That didnt make it any newer " " Dont antique the equipment " Last edited by KQQL IT; 01-22-2010 at 03:59 AM. |
Re: shock mounts
thanks guys going to do a little more looking today I will keep you posted
Chris |
Insert Witty Text Here
Re: shock mounts
I don't quite understand your situation, but my truck was built in Canada, and my shock mounts came with my shocks. I have replaced them twice with no problems.
Are you sure your holes aren't just wallowed out a bit from having loose mounts flopping around in them? Slonaker |
Re: shock mounts
They are not wallowed out. when I got my kit I checked the studs and they were 1/2" and the frame hole was 5/8" so I called Belltech and they do not make a 5/8" stud. So I called Monroe suspension and they sent me some information on the right size stud. So I have that covered. When I first called Belltech about that issue the first question they asked is if the truck was built in Canada. So I need to order the new studs from Monroe and hopefully Belltech will make it right considering I spent over $600 for a kit that was supposed to bolt in and I have spent about 2 weeks dealing with this issue and now have to pay about $30 for the studs. So if anyone needs some 1/2" studs I have some extra. I measured the old studs with a micrometer to be sure they are 5/8"
Chris Last edited by chrismoore701; 01-22-2010 at 12:12 PM. |
#13 |
yeller
Re: shock mounts
I think I have a new set you can have, if you pay shipping. I will look tonight, just let me know.
Jeff 73-87.com 73-87.com Facebook page 73-87 cab corner 6x9 speaker brackets for sale 67-72 cab corner speaker brackets for sale 47-54 cab corner speaker brackets for sale |
#14 |
Re: shock mounts
Do you have a set of 4? I can buy new and stillen who I bought the dropkit from said they will try to pay for the studs, but they have not said for sure. So if you have some I will just do that to save the hassel. thanks
Chris |
#15 |
yeller
Re: shock mounts
I believe I only have 2...I will look when I get home tonight to be sure.
#16 |
Kid's Mechanic
Re: shock mounts
Napa is a good place,and the help section at the parts stores.Have in the past gotten shock studs from Napa.
#17 |
Gentleman Jim Driver
Re: shock mounts
Easiest and quickest way to get them is to go buy some $15 shocks from your local parts store. They have them with them. Sell the shocks at the next swap meet for almost what you paid for them...
Joe '75 GMC Gentleman Jim '84 Chev C10 Short Wide - Super duper plain (manual steering, manual brakes, no dome light, no cig lighter) '85 Chev C10 Short Wide - Super plain Vortec 4.8 4L60E trans also: '81 K30, '83 C30 Crew Dually, '84 M1028 CUCV, '85 M1009 CUCV, another '85 C10 SWB, '89 R3500 Flatbed |
#18 |
Re: shock mounts
or just return the shocks to the store w/o the studs. They won't notice... maybe.
#19 |
Re: shock mounts
Any luck Jeff? Thanks for looking
Chris _______________________________ 1979 Chevy Stepside SPORT 2018 Chevy Silverado, 39 years apart ![]() My build 2008-2016. http://m.imgur.com/a/bURrE |
#20 |
yeller
Re: shock mounts
I just looked, I have 2 mounts, new.
#21 |
Re: shock mounts
Jeff I do appreciate you looking, but I think I am going to buy from monroe. this will be sure they will all be the same
thanks
Chris _______________________________ 1979 Chevy Stepside SPORT 2018 Chevy Silverado, 39 years apart ![]() My build 2008-2016. http://m.imgur.com/a/bURrE Last edited by chrismoore701; 01-23-2010 at 12:49 AM. |
#22 |
Re: shock mounts
I just measured a spare set I have, and they are 5/8. I don't understand how a Canadian built truck and a USA built one could have different shock mounts. I have replaced my shocks a few times, and never asked for anything special. If 5/8 is not what they typically come with, how do I keep getting the right ones? It sounds to me like Belltech just sent you the wrong ones.
Slonaker |
#23 |
Re: shock mounts
Belltech told me they researched it. I bought the kit from Stillen.com and they talked to belltech and they told me the same thing stock is 1/2" I am going to go to the autoparts place this week and see if they have a set of stock shocks in stock and look at the pin. if belltech is jacking me around it is time to go higher on the management train thanks guys
Chris
#24 |
GoatLube Experss
![]() Join Date: Oct 2009
Re: shock mounts
really !
Goat Lube Express, locations in Qalat,Afghanistan & Clarksville, Tn. '87 R30 dually 454/TH400 '85 1/2 ton CCSB '92 S10 350/350 '84 MonteCarlo 383/PG/9"ford '78 Malibu wagon 350/350 '78 Cutlass (project family car) '96 S10 Jimmy (Moma's) |
#25 | |
Re: shock mounts
Slonaker I took your advice and decided to go check out a stock shock. Went to Autozone, I know I just figured it was easiest. They had one in stock and it had a 5/8" stud. I got straight in the phone and called the management and told them my dissatifaction with the sales guy I was dealing with. He is going to look into it and call me back. So after getting screwed around for a couple weeks now we will see what they come up with. Thanks for the pointers Chris
